Results 1 to 40 of 65
Thread: The Rebuilding of Motivation's GSX!
    The REAL Scrapy :)
    Oct 2008
    Default The Rebuilding of Motivation's GSX!
    Well folks. I am the one who acquired his shell and am currently in the process of rebuilding it. Here is the progress so far, and will update as time goes on. I'm almost ready to drop in the engine/tranny!
    Here is Motivation's GSX next to my GSX, right after I towed it home. I decided to pick his up because it is cleaner and ACTUALLY has a title!
    Donor GSX ready to tear down... RIP
    Waiting to go in the garage. Had to finsih clearing out the garage and do some wiring that required outside light rather than a dark garage
    What's going in the Gold GSX... (Too bad the red wont match anymore!)
    When I got it
    What a messy interior!
    Cleaned out
    Interior installed!
    Dirty Dirty!!!!!
    Getting Cleaner...
    A/C Removed. I wont be needed that shit
    What a mess of wiring! I HATE rewiring!
    Allll better and organized!
    Missing MAF plug
    There it is!
    Some more wiring work done near the ECU. Did I mention I hate wiring?
    I Think I will wire the fan in my own way. So out goes the old switch
    MORE Missing plugs (Thermostat housing) -I havent wired these plugs in yet
    Rewired the fuel pump with 10gauge wire
    Red GSX being Disassembled
    Both FINALLY in the garage!
    That MOTHER FU^#*ing fuel line fitting just wouldnt come loose
    Fixed the DSMer way
    Stay tuned for more progress!
    1990 Eclipse GSX - 13.0@ 108 on old setup
    1990 Eclipse GSX - "The Whore" Shell being built
    2001 Dodge Dakota - The pizza delivery-mobile
    Looks like fun. Good luck with it.
    Certified Gearhead redfire6i's Avatar
    southside
    great to see that this car will finally be back on the road! good luck, keep up the good work!
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    looks good
    I wish i was brave enough to tackle wiring. Behind my radio is a rats nest...
    somewhere, GA
    Great detail!
    G/L
    '82 TE72 SR5 Sport Coupe
    3tc
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    @ "fixing it the dsm'er way"
    The REAL Scrapy :)
    Oct 2008
    Its annoying, but if you take your time and see where each wire leads, it works its self out rather quickly!
    Quote Originally Posted by collins View Post
    Glad someone caught that =P Its what we do! Cant get it off? Cut it off! (Insert dirty joke here)
    AKA THE BROWN MAN
    Kennesaw, Georgia, United States
    remember keep lots of washers, zip ties and oil
    thats what we always kept around when it was last running lol
    The REAL Scrapy :)
    Oct 2008
    Well I plan on building this right to where it wont need anything at all! Not even carrying around tools (Which I will anyways... Cause its a DSM) My ultimate goal is to run 11's and deliver pizzas the next day in it
    C7 On_Her_Face's Avatar
    Duluth
    I'd like to see the rest of this!
    Senior Member G.C's Avatar
    Forgot
    I liked it until you did that dsmer way . ahahah g/l with build.
    :idb:
    Spraypainter Gabe's Avatar
    United States of Atlanta
    impressive!! keep it up dude
    Gabe
    Papasmurf #3!! Oz10's Avatar
    Keep up the good work.
    holy shit, i like, keep up the good work
    Peek-a-boo mofucka what now?!
    ѦʈʃѦŋʈѦ
    Nice work, man! Keep us updated. GL with the build.
    The REAL Scrapy :)
    Oct 2008
    Thanks everyone!
    More done day, but nothing that was picture worthy.
    - Converted to non-cruise control throttle cable
    - Extended the alternator plug wires to the back of engine bay
    - replaced some nasty looking fuses
    - Installed clutch cut for DSMLink
    Still need to be done:
    Buy more jackstands because I need more than 1
    Need to swap axles over from red to gold car
    Drain oil and tranny fluid but my pan is full
    Pull engine
    Swap motor mounts over into Gold car
    Swap Oil filter housings to a forward facing one (It came in the mail today)
    4 bolt rear end swap
    Driveshaft install
    THEN::::
    PLAY WITH DSMLINK!
    AKA THE BROWN MAN
    looks promissing(sp) good job so far want more pics!!!
    The REAL Scrapy :)
    Oct 2008
    Okay here is one to throw in. My new oil filter housing. Faces forward rather then jutting into the exhaust path. There was just nothing to take pics of today.
    The REAL Scrapy :)
    Oct 2008
    I hope to get alot accomplished Monday on my day off
    ALL CAPS JITB's Avatar
    looks fun! what else is gonna need to be done to the motor?
    The REAL Scrapy :)
    Oct 2008
    absolutely nothing! my engine im pulling out of the red car only needs a new Oil filter housing. Other than that it runs like a champ!
    Quote Originally Posted by ScrapMetalDSM View Post
    naw i was talking about to get to your goal of 11's!
    The REAL Scrapy :)
    Oct 2008
    Oh gotcha.. besdies what I already got, A sheet metal intake manfifold, cams, and a nice tune on race gas should get me there I HOPE. I hope to achieve this on stock block and head (minus the cams)
    The crack
    Ahhhh Tim would be so proud
    Augusta Ga
    nice bullseye housing on the turbo ... and nice project ..lets pray this dsm actually makes it out the garage .. good luck man ! lol
    93 sol Si
    95 sol S
    95 sol Si
    The REAL Scrapy :)
    Oct 2008
    Thanks! And this DSM WILL, I repeat WILL make it out of the garage. I'm thinking by mid january at the LATEST. It might end up being tuesday but I hope on monday to have the engine out and in the Gold GSX!
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    gl wit project bro
    AKA HIZDAWAY
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    DO work!!!
    AKA THE BROWN MAN
    elevens should be no problem tims old setup was easily a twelve second setup just ran into a few problems we later found after it was taken apart
    The REAL Scrapy :)
    Oct 2008
    Fack I am tired! So far I went tool shopping, pulled axles out, and removed the engine. I am stuck on removing the oil filter housing now. It's been a day off of Pain in the asses. Onto the pics so far.
    Pulled axles out ( 1st PITA)
    Slowly pulling the engine out. Checking for snag's.
    1st snag. Alternator caught on Brake Master Cylinder. have to drop it back down some and swivel it.
    Oh wait! My damn engine lift is broken and once you lower it just a hair, it wont go back up! So what do I have to do? lower the engine back in all the way, Pull engine lift out, lower it completely. then re-raise it and hook the strap back up
    2nd attempt...
    SUCCESS!
    Getting that bitch back in the gold car will be a precision drop. There wasnt ANY wiggle room whatsoever! Granted the angle the motor got lifted out at didnt help. But I had to do the best I could with what I had to work with.
    I love you long time, Sir.
    Awesome to see this going down with my old car
    LAWRENCEVILLE
    that engine hoist would work alot better if you pull the lift are out!
    Hella stock member!
    The REAL Scrapy :)
    Oct 2008
    Well the problem with that is that it then hits the top of the garage door opening and i cant get it out! I think I may need to bleed the lift, because once I lower it just a tad, it wont go back up, and i have to start completely over!
    Thanks catnip. I lub you too no homo...
    >^..^< Meow Bitch nintendobratkat's Avatar
    Port Royal, SC & Athens, GA
    Nice. = D Can't wait to see it finished.
    R.I.P. Brian Mough, Leisa Lowenthal, Scott Hayworth, Valerie Antranikian. Gone but not forgotten.
    FB
    Wow the guy you got the car from absolutely trashed it. One of my buddies owned the car a while back and it was in fantastic condition at that time.
    The REAL Scrapy :)
    Oct 2008
    Nah, He didnt trash it. It just got passed around so much that it got neglected. but no worries, I'm returning it to its pristine condition
    North Augusta, SC
    Trashed it, huh?
    Let's see, I had actual Evo 8 recaro seats in there, different wheels, was ALWAYS kept clean, got props EVERYWHERE I went with the car. I cleaned this car up even more from when your buddy had it. Promise you that. You can ask anyone that has seen this car in person when it was on the road. Remember, it's been being parted out for 8 months. The gauges were hanging out like that because the wideband was sold to someone else. Actually, the OP, is the one that pulled it out.
    I love how everyone thinks the car is supposed to stay in prestine condition when being parted out. He got this car at a HELL of a deal, I lost my ass on this car. I easily put 2-3k with in the first month I had it, doing stuff to it. (ask "catnip", "flipking", or anyone else that knows me)
    Anyways, Michael, props on what you are doing with it. Went to a great guy. Wish I could have kept it, but it definitely went to a good guy.
    Back to being stock and slow
    Tim (Motivation) is right. He ALWAYS kept that car clean. He was always upgrading or repairing the car. When I sold it to Tim, I got compliments EVERYWHERE I went. Tim made it even better.
    North Augusta, SC
