Results 1 to 20 of 20
Thread: gsr vtec problems
    eg6
    Apr 2009
    Default gsr vtec problems
    mods please delete.
    is the timing right? is the check engine light on?
    eg6
    Apr 2009
    car runs fine and everthing and theres no cel.
    oil level???
    Speed O works correct???
    Bad knock sensor????
    Norcross
    Quote Originally Posted by pinedo88 View Post
    then wats the problem?
    Quote Originally Posted by j0nbunklah0m View Post
    No Vtec YO!!!!
    eg6
    Apr 2009
    ill check and change. thanks ,the car has vtec but doesnt pull like it supose to and it engages in diff. rpm's
    any cel? is it hitting vtec @ different rpm under the exact same conditions (wot, temp, etc), or does vtec rpm change based on varying throttle position?
    not pulling the same in vtec could mean you have one of the cams out of time when you did the belt...double check that. you may have 2 different problems unrelated to your issues.
    check:
    1. cel
    2. cam timing
    3. oil level
    4. jump vtec solenoid directly to see if it kicks everytime you jump it
    5. check oil pressure @ from orifice on the head to make sure you have plenty of pressure
    6. check to make sure the oil pan isn't dented and too close to the pickup
    Quote Originally Posted by scttydb411 View Post
    check:
    1. cel
    2. cam timing
    3. oil level
    He said NO codes
    one thing everyone forgot to mention. Is your oil pan dented in? If so You might want to check your oil pickup.
    Quote Originally Posted by mp82 View Post
    West palm beach
    NO ADVERTISING
    -IA MANAGEMENT
    B-Town Crunk Force
    Statesboro, GA
    Refer to #6 in Scott's post.
    dang I over read..haha
    Out in the Boonies
    I think it's just an oil issue.
    Quote Originally Posted by DC2NR View Post
    haha...me too. didn't see the reply that said not codes. it happens to all of us.
    you have a gsr?
    Hwy 315
    everyone forgot to mention that it's probably just an oil issue.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    eg6
    Apr 2009
    ok so today i fixed the dent in the oil pan as well as pick tube it should be getting enough oil now, but it still dnt pull hard dnt even chirp 2ndnow im lost dnt know wat to think of next,now it kicks in at 4200 and 5800 any help.
