Results 1 to 22 of 22
Thread: Clutch problem
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Default Clutch problem
    I was driving today down the highway everything was cool I get off the exit and go to push the clutch down to pull it out of gear and the pedal sunk to the floor and stayed there and I couldnt pull it out of gear.So I used my foot and scooped the pedal from the floor and it came back up and out of gear but now when i drive there is no hardness to the pedal anymore and to shift I have to push the pedal all the way down to the floor.The pedal feels kind of squishy but still comes back up but i cant feel where the clutch is anymore,any ideas?
    Out in the Boonies
    Check your clutch fluid lately? May have some air in the system.
    Quote Originally Posted by DC2NR View Post
    x2
    KINGZOFSOUTHTOWN
    Norcross
    x3.... bleed your clutch.
    -hmgdrfter-
    PP TRACK 350Z
    Oct 2008
    x2
    Fluid levels the same but before i checked today i havent messed with it how could air get in it? And you dont think it could be the clutch pump or anything else related?
    Most likely need a new clutch master cylinder, is there any fluid leaking from it?
    Oct 2008
    Quote Originally Posted by speedminded View Post
    No leaks
    Quote Originally Posted by STRteg View Post
    No leaks
    If the pedal is sticking in the down position then there is obviously a pressure loss somewhere: whether it's an air pocket in the line, leaking somewhere, or getting past the plunger in the master cylinder which will eventually leak down the firewall...either in the engine bay or under the dash.
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    +1
    Oct 2008
    Its not sticking down anymore it only stuck down once now it feels soft and squishy
    Probably because the fluid is so cold...once it warms up it will be a different story.
    Oct 2008
    Perhaps so however i drove it for a while and I mean a while while it was more than hot
    What warms up the clutch fluid?
    Oct 2008
    No the overall temperature of the engine I drove on the highway for about 40 mins or so
    My point exactly. I'm sure the engine bay warms up the master cylinder a bit but the fluid isn't exactly in contact with a heat source like engine oil, coolant, or brake fluid so I'm sure it takes considerably longer to become thinner.
    Oct 2008
    So your saying it was just acting up because the fluid was cold?
    replace clutch slave cost 15 at autozone and master cylinder cost 50ish from autozone problem solved
    Slow Aeroscout977's Avatar
    Nov 2009
    Lima, OH
    Back when I had a 93 Stealth I had a slave cylinder go out. No fluid leak but I had no pressure on the clutch pedal.
    No, it quit acting up because the fluid was cold. It will most likely go back to the same symptoms you were having before...
    SAS..22 Njobe's Avatar
    Quote Originally Posted by ASE*Tech View Post
    these and the problem should be fixed.
    Oct 2008
    Thanks everyone
    Oct 2008
    Ok so heres the update as of right now I went to the zone (autozone) and bought a new slave cylinder and clutch master cylinder and clutch fluid and I'll be changing it all out tomorrow i'll let everyone know how it goes
