Results 1 to 15 of 15
Thread: tranmission roaring
    Stang Mod slostang's Avatar
    Southside
    Default tranmission roaring
    i have a 97 mustang gt 4.6L with a tremec t-45 5 speed trans. i changed the fluid in the trans today with 3.5 quarts of dextron 3 ATF just like tremec reccomends. and i filled the trans with the new fluid through the shifter if that matters. now the trans makes a slight roaring noise that gets louder as the revs increase. any opinions?
    was it doing this before?
    what did the old fluid smell like? Reason I ask many used car sellers that trys to hide a tranny noise like this they add gear oil that smells like rotten eggs and this makes the fluid thicker...
    and using the shifter housing is fine, if you look down you will see the gears so your pouring it right on top... In my mustangs,cobras I use 50/50 half an half dextron/Gear oil 80w90 (lucus)Brand and this thickn the fluid for better high temp protection with out tearing the brass in the tranny like full 100% gear oil would do. I would re check the fluid, on the passenger side there is a bottom bolt and a top upper bolt plug. take the top one out with the car level and check with poking your finger in and see if you see fluid on your finger. If not add until it runs out the top hole.
    If its full, drain about 1.5 quart out and add that much 80w90.
    But these trannys suck assssss T5 T45are the worest ones, and if it still makes the noise you will need new bearings which a used tranny would cost 500ish used
    Southside
    nah the old fluid was red and smelled like normal atf. and it never did it before. but ill check the fluid level tomorrow and see whats up.
    Quote Originally Posted by slostang View Post
    then it sounds like its low... Or you left the foam part out of the shifter that makes the noise lesson so you dont get sound inside the cockpit. Also heat and air flow also,,,,
    Southside
    Quote Originally Posted by ASE*Tech View Post
    damn you're good. i couldnt get the thick rubber boot to line up with the metal plate on the last bolt i put in. ill re check my work tomorrow.
    Been working on cars too long lol
    Southside
    lulz. ill rep you as soon as it lets me again.
    YOURMOM tnomud's Avatar
    Coweta
    Toss some Lucas in there, ATF in a Ford Manual is what it calls for, but that's assuming you live places that it gets cold. My Ranger did that, I tossed in a 1/2 qt of Lucas 80WT with the ATF and problem was solved.
    Quote Originally Posted by tnomud View Post
    Already said that
    Coweta
    Already said that
    Just giving a vote of confidense from personal experience.
    thanks, But I assure he trusts me as He and I know each other .
    But its good info
    Any word?
    barrow county
    well if you put too much fluid in the tranny, it'll cause the fluid to form bubbles. maybe that's what your hearing
    just a guest
    Quote Originally Posted by blue_gt View Post
    just a guest
    Southside
    my transmission has rabies! ITS FOAMING AT THE MOUTH SON! AHAHAHA.
