Results 1 to 13 of 13
Thread: Different heads on a d16?
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default Different heads on a d16?
    My question is what are the diff. Heads that will bolt up to a d16z6 block for more power?
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Keep that head or do a Y8 head its OBD2 though. All D series are interchangable but your vtec block needs vtec head!! Just build it to make power.
    Work in progressneed slicks!
    www.jjspec.com Macon, Ga
    I have a Z6 head on my D16Z6. I have used the Y8 in the past also. Look at the sig.
    known as Charles
    I would keep the Z6 head mainly for the cam profile and timing setup. You can put a Y8 on it and gain a little compression but that is about it.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    the county
    i, personally, think the z6 is prob. the best way to go on single cam engines.
    instead of getting a new head, upgrade the cam, springs and retainers. it will help out the top end some.
    \m/>_<\m/ dorin48's Avatar
    Canton
    Quote Originally Posted by Main Stream View Post
    Also the Z6 has a better top end potential due to straight ports.
    The Y8 will up the compression slightly but at the cost of offset ports.
    Nov 2009
    Bremen
    Quote Originally Posted by jjmastertech View Post
    What's your set-up though?
    Quote Originally Posted by Jdmsol View Post
    a large turbo with a green integra
    buford ga
    z6head>y8
    boost it , changing heads is a waste of time and money ... throw some real power into that swap
    AccuracyPerformanceAutomotive
    Quote Originally Posted by Tech5 View Post
    x2 doesnt matter what head when you boost it.
    500whp of spinnin fury!!!
    West palm beach
    Quote Originally Posted by QWK D16 View Post
    NO ADVERTISING
    -IA MANAGEMENT
    Quote Originally Posted by Purple Power View Post
    Actually, it isnt that big. I have a huge turbo sitting on a table near the car, lol.
