Results 1 to 13 of 13
Thread: How do u clean the inside of a motor?
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default How do u clean the inside of a motor?
    I have a motor dis.( D16z6) and was wondering how to clean the inside of it as far as what to use? (had the block hot tanked)
    aye bro .:Stirfry:.'s Avatar
    purple power
    ATL DAsquad Member #9
    www.jjspec.com Macon, Ga
    Parts washer. If the block has been hot tanked and everything is disassembled put everything in a parts washer and go to town. If it is bad enough send it to the machine shop and they have stuff to clean it with.
    Nov 2009
    Bremen
    Ok thanks, just asking cause I didn't want to use something that would leave a film and screw something up
    Quote Originally Posted by jjmastertech View Post
    ^^ what he said.
    but if you wanna go super cheap DIY/ do what i said.. lamo
    Stang Mod slostang's Avatar
    Southside
    purple power, simple green, brake cleaner, etc. pretty much anything will work.
    Quote Originally Posted by Jdmsol View Post
    Stirfry was correct on the purple power also. Helps if you can get the oil film off first then the Purple Power will do wonders! After cleaning, wash with warm soapy water and get all the residue off then put some WD40 on the parts if you are worried about residue.
    Quote Originally Posted by .:Stirfry:. View Post
    purple power
    o rly?
    ALL CAPS JITB's Avatar
    i used gasoline...lol
    yeahhhh...... Nick Jeezy's Avatar
    a vat.
    Quote Originally Posted by Purple Power View Post
    o rly?
    rly!
    Quote Originally Posted by JITB View Post
    I used nitrous once. It cleaned the aluminum right off the piston, lol!
    use a pressure washer, works for me.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    brake cleaner is great and evaporates.
