Results 1 to 40 of 47
Thread: I have coolant in cyl #4 of my B18c1
    Warner robins ,Ga
    Default I have coolant in cyl #4 of my B18c1
    collant in cyl #4 on my 97 gsr stock boosted.
    could it be headgasket? or cracked sleeve?
    or something else?
    motor almost turns over but wont stay on
    please help!!
    Southside Ridin HATCH
    it very well could be the gasket.... And or warped head...
    have u done anything to it recently??
    Warner robins ,Ga
    yes just boosted it hit boost about 40 times in the day and later that night this happened?
    Middle, Ga
    Damn PT, are you talking about Chris's car?
    "Damn, Its Tyler"
    RaceReadyDevelopments
    got all coolant lines in the back hooked up correct??
    Warner robins ,Ga
    that im not sure of but it did run for the whole day without this problem occuring but why would it just start out of no were if the lines were hooked up incorrect?
    Warner robins ,Ga
    and this is chris and yes my car Ftl
    SwiperNoSwiping!!
    I'd try with finding the leak, and once you find the leak it can tell you what to fix. Most likely would be the headgasket, or if you didnt put any head studs in it, could be some head lift.
    u remind me of a wigger !
    it the headgasket
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Warner robins ,Ga
    the leak is not external so idk how to find the leak if its in the internals? unless i remove the head and im going to i just wanted to get some opinions and stuff. but if its just some collant lines backwards or hooked up wrong on the intake mani witch is blox or on the block could that be the problem?
    those lines in the back on the mani..
    If the one from the Heater core (fire wall) is switched around with the 'U' shaped hose (on mani).. Directly next to it.. If those are switched you have problems
    Other than that^ most likely headgasket
    Warner robins ,Ga
    ok i will take a look
    JDM TYTE AnthonyF's Avatar
    headgasket.
    You can repair it the right way or use BARS Headgasket leak repair which really works.
    -Ant.
    The Carbon Fibered R6
    Warner robins ,Ga
    ok looks like im takeing the head off. :/ but why is everyone eliminating the crack sleeve?
    what signs happen with that
    aye bro .:Stirfry:.'s Avatar
    its a cracked water jacket in the head, since its a certain cyl.
    ATL DAsquad Member #9
    Warner robins ,Ga
    Southern Speed
    Macon
    has it been recently tuned?
    Middle, Ga
    Quote Originally Posted by xdavidscenex View Post
    Ahh shit man, that sucks. Hope you figure it out.
    "Damn, Its Tyler"
    Middle, Ga
    fuck i should have listened to pt da king and kept the supercharger!!!
    LOLOLOL. PT, you so crazzzyyy.
    "Damn, Its Tyler"
    now you need a new head..
    Warner robins ,Ga
    it didnt run hot
    Warner robins ,Ga
    so thats not possible i have no collant in my oil
    SwiperNoSwiping!!
    Just go pull it off and see with your own 2 eyes instead of guessing....
    lol im just sayin'
    You either a have a really bad intake manifold gasket (on cyl # 4 where the coolant can pour directly into the cylinder via intake runners) Or you have a crack in a coolant passage in the head(or on spark plug tube I have seen them fill a cylinder this way). Or you can have a severely blown headgasket. Or you may have cracked a sleeve. Depending on tuning, boost pressures would help narrow some of those out.
    Middle, Ga
    Should have just left it Supercharged. lolol.
    "Damn, Its Tyler"
    Warner robins ,Ga
    lmao
    Warner robins ,Ga
    so what would be the case if i had colant in all four cyl and the #4 being the woorse?
    did you even take the head off yet? get the head off first chris. lol
    check the intake manifold gasket #4 has that coolant passage right by it.
    LAWRENCEVILLE
    since you are pulling the head. check the intake gasket,headgasket and replace them! also how much coolant is getting in? when i cracked a sleve on my boosted ls is would send steam/smoke out the ext like a train!
    Hella stock member!
    Warner robins ,Ga
    it would sned steam smoke oout the what? like a train?
    LOL @ some of the answers in General Tech.. a few of these guys don't need to be offering advice.
    __DailyGrind
    x2
    Warner robins ,Ga
    Middle, Ga
    Oh wow, I love how you just put that but don't give any advice. Dumbass.
    "Damn, Its Tyler"
    Quote Originally Posted by i4_garage View Post
    x2
    Quote Originally Posted by NVM View Post
    x2
    take it off and take it to reeves!.. lol
    Warner robins ,Ga
    lol yeah ok
    (not)
    roflcopter V-Spec II
    Norcross
    I had to fix the thread title.
