Results 1 to 21 of 21
Thread: boosted d16z6
    southside ATL
    Default boosted d16z6
    alright so i got a gsr im building for boost. but in my car right now is a z6. i love the gas saver, and want a little more fun out of it. I already have a ebay cast iron manifold with the wastegate flange on one cylinder, but im thinkin about blocking that off and running a internal wastegate turbo. maybe a T25 off a twin turbo 300z A/R 48. like this one. link
    idk if this is a good turbo to use.
    I just want this to spool quick, for a little more fun.
    My power goals - high 100whp maybe a little over 200. This is my DD
    Budget - 800
    Good setup? Input?
    Twan Jdm94Coupe's Avatar
    Fairburn
    sell the gsr you are building, and boost the sohc...... you won't have to buy axles, mounts, shift linkage, etc that goes with doing a b series swap..... d series motors/parts are cheap if anything messes up, and b series just flat out cost too much for the power you're trying to make.
    If you still want to go b series, let me get your d16z6 shortblock, lol.....
    it's true! QD my fav tmracing83's Avatar
    Rockdale, GA
    Lolz at final comment^^^
    I just had boosted d16z6. Just fuckin boost the d! Trust me it gets great mileage and I had 440 cc rc injectors. The power is plenty if you do it right. Boosted D's are badass. Do it. Mine was fast as shit. I'd eat 350z g35 and S2000
    OBAMA..... *IS*
    One. Big. Ass. Mistake. America.
    Fairburn
    Quote Originally Posted by tmracing83 View Post
    reps 4 sense of humor!
    southside ATL
    +reps
    but nobody answered my question. are my goals reachable if i use a T25? What turbo should i run for a fast spool
    the county
    you should be able to get around 200hp with a t25, upgraded injectors, and a good tune. i'd do some internal work on the bottom end to a longer life.
    with $800, eh, maybe. if you build you own kit and get hooked up on some stuff.
    Senior Member cm7k24's Avatar
    kennesaw
    Quote Originally Posted by j0natell0 View Post
    +reps
    i have a td04e on my y7.
    bitch spools instantly pretty much.
    and can meet your goal range pretty easy with a good tune.
    Rockdale, GA
    I had a gt28rs I believe it is. Re "disco potato" on my z6. With 440 rc's and tuned on chrome. And it was lightly built. Made 217whp at 16 lbs
    OBAMA..... *IS*
    Rockdale, GA
    Wish I could actually help but I'm a noob to turbos but I will always live them from now on...
    OBAMA..... *IS*
    West palm beach
    boosted D ftw...
    NO ADVERTISING
    -IA MANAGEMENT
    buford ga
    I told jon to stop wasting money in that b-series and put some of that bread back in his pocket and make more power and torque on a d-series for the $ he is spending in the b not to mention still drive around and get 26-30mpg
    IA Member SRK420a's Avatar
    Lithonia,Ga
    boost the d-series!!! Its wayyyyyyyy cheaper than swapping the b-series. after you swap you are still stuck will a motor under the 200 hp mark..... D-series ftw
    www.jjspec.com Macon, Ga
    I have a GReddy kit for a D Series that I have for sell. Made around 225 to the tires. All you would need is some form of engine management. D series boost is def the win! I have the 94 Integra with the boosted single and have run a 11.1 @ 130 and still drive it around on the street with no problems.
    Fairburn
    Quote Originally Posted by jjmastertech View Post
    point proven. no need to go b series unless you wanna run faster than 11 seconds, other than that, d ftw, lol
    Quote Originally Posted by Jdm94Coupe View Post
    Hopefully I can get a 10 out of it before the end of the year. If the track will hold the power should be able to get it done on a 22 inch tall slick. I had to pull a lot of power last Friday night in first and still went .04 sec faster than the previous best pass with 3 more mph. Remember, the transmission is still stock with an open differential and I am using stock replacement axles. This year I have definately been impressed with the D series!
    Around metro-ATLANTA & IA!!
    D is soo cheap!! if the d is already there...just get some solid filled motor mounts(they like $120 for 3 of emm on ebay, they work) and a nice stg2-3 clutch, T25 on y7/y8 10-12psi makes like 190-205ish?? give or take some....but hey torque #'s are way better than any b-series ive personally seen seen...its actually porportional to the hp. im building my D, its cheap man...im aiming for 320-340ish and thats plenty enough for my front wheel drive street car...
    known as Charles
    The stock T25 from a 300z will be a little small for the Z6. You could make about 200whp but that will about max out that turbo. Also, the manifold you have prob has a T3 flange on it and you will need one with a T25 flange. The stock Z6 (with headstuds) can do 250whp no problem with a good tune. If you want a small turbo that is fun I would try to get a T25 from a SR20. As for the $800 budget that would be a little tight if you still have to get injectors, chipped ecu, and tuned.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    i have a T3 turbo forsale....great for stock SOHC boost....turbo will fit t3/t4 turbo manifolds..lmk i give you good price!
    T3 TURBO~~~~T3/T4 Flange
    georgia
    i made 200whp with a t25 similar to the one your thinkin of running on a stock d16. power came quick spooled really fast,lots of fun!!!
    yes i am....
    Quote Originally Posted by THEONE View Post
    u have the t25 off the sr20?
    georgia
    Quote Originally Posted by k20ej8 View Post
    nah,i had a knock off ebay turbo internally gated at 8psi,and it worked great .....
    yes i am....
