Results 1 to 29 of 29
Thread: Turbo exhaust
    Stay Humble
    WV
    Default Turbo exhaust
    I'm hooking up my Kit on my Si and wondering what the ideal exhaust size would be? its a 18g greddy turbo for now but plan on upgrading it later on down the road... so 3"? 2.5"?
    And im probably doing straight pipe. any problems with that?
    Senior Member cm7k24's Avatar
    kennesaw
    i'll give you my 2 1/2 and you give me your exhaust,
    i'll do all the work. ill even throw in a test pipe
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Go with 3" bro especially if you plan to upgrade later, don't waste time or money. Thermal is allways GREAT!!!!!!!!!! HKS is as well if you can find it.
    Work in progressneed slicks!
    Stay Humble
    WV
    Itll be just a straight pipe man.
    What you mean by thermal?
    Jamal- i already got 2.5 lol
    Augusta Ga
    i run 2.5 and im only running 8 pounds tho .. but if you plan on going past 10 .. i would do 3.
    93 sol Si
    95 sol S
    95 sol Si
    Respect my Authority SilverSurfer's Avatar
    The Barracks
    i would go 3"
    thermal the exhaust is what he meant
    Stay Humble
    WV
    ok then whats thermal the exhaust mean hah
    thermal, exhaust brand, you know like hks apexi
    Stay Humble
    WV
    ahhhh never heard of them. thats nuts
    Stay Humble
    WV
    cant i just take it to a shop and have a custom straight pipe made?
    emissions isnt an issue
    The Barracks
    yea
    Stay Humble
    WV
    i guess thats not a popular thing to do lol
    Certified Gearhead wwli's Avatar
    Your better off in getting a full exhaust system from companies like Thermal Research because the quality of it you cannot get at a local shop.
    I got mine done at MS and they fucked it up. Told them how I wanted it and they did not do what I had requested then they were like well you should have told him in advance, in part I did and got screwed on the labor. A simple exhaust job turned into a complicated one so stay away from these people....my 0.02.
    EK needs a new tune? baby needs more boost so a good tuner is needed....anyone?
    Stay Humble
    WV
    ok can do.
    Norcross
    i got a freind that works at a muffler shop that can do it. he does good jobs too.
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    3 " no other way!
    Flowery Branch, GA
    3" for the downpipe back. Even 4" would not be a bad idea for the down pipe, especially if it is a internally gated 18g. Try to get one that is mandrel bends if you can. 3" downpipe back will support a LOT of flow.
    ---Mike
    Stay Humble
    WV
    ok, yea my down pipe is Ginormous! lol
    and ill stick with 3" for sure
    www.jjspec.com Macon, Ga
    I am using 2.5" custom mandrel bent aluminum exhaust. The downpipe is mild steel. Made 450 whp @21 psi and am running 24 psi and low elevens(look at signature). The whole exhaust weighs 7 lbs. It is on a d series. What size is your turbo outlet? Making everything work together is key to making good power. Here is a pic before we added the muffler(which is a custom fabbed aluminum piece also):
    kennesaw
    Quote Originally Posted by chaseamundo View Post
    chase, its the same shit rashad has.
    Stay Humble
    WV
    JAMAL - thanks i realize that now haha
    and im not sure of the outlet size. td04 18g turbo....??? not sure
    How much psi are you planning on running? You can go with 3" if you would like, but it is not necessary. For your set-up, 2.5" would probably be more than enough for what air that 18G can flow. As stated before, 450whp was put down using a 2.5" exhaust. 4" is ridiculous for an 18G turbo, do not do that. The pain of making it and the $$$ spent doing it will be a waste, when you can make the same power from a 2.5" exhaust. Again though it is up to you... but I believe 3" is not needed and 2.5" would be a better choice for overall performance for your 18G and engine.
    Quote Originally Posted by jjmastertech View Post
    What size turbo are you running?
    Stay Humble
    WV
    Quote Originally Posted by turbomirage View Post
    oh ok thats good to know.... but keep in mind ill be wanting to upgrade turbos later on down the road...(are you ricky?)
    kennesaw
    yeah thats him
    Yes, that is me. But yes, if you are planning on upgrading down the road then 3" would be fine.
    kennesaw
    ricky when are you gonna come check out my civic! lol
    Stay Humble
    WV
    oh alright, my buddy jamal (im sure you know him) told me about yuou and your car. sounds sick. been waiting to see this thing in person haha
    but ok 3" it is
