Results 1 to 10 of 10
Thread: Y8 Oil pump issues
    my momma's house
    Default Y8 Oil pump issues
    After a solid month or so, after I spun a rod bearing on a freshly tuned motor, I did some research, and it looks like alot of folks have issues with Y series oil pumps at high RPMs. I was on another forum and there were a few options.
    1. Shim my Y8, or Z6 oil pump for a high flow rate
    2. Use a Z6 oil pump
    Now, as far as the shimming goes, has anyone heard of this? and do you think it's a good fix for the issue? Should a Z6 oil pump do the trick? Some people even went as far as using a Z6 oil pump, and oil pick up, and pan, but they said it wouldn't allow for a dip stick, and that doesnt sound like a solid move for me.
    Any positive advice would help. thanks in advance!
    Trend settin'
    West palm beach
    lots of people shim the pump, but I would just buy an aftermarket high volume pump. here is a link http://www.importperformanceparts.ne...umpsmitsu.html
    NO ADVERTISING
    -IA MANAGEMENT
    my momma's house
    Awesome. I read up on the TOGA, and there were mixed reviews, but it's look like my first option so far. Reps.
    Trend settin'
    my momma's house
    I found this on another forum, and i'm very interested in how this could possibly turn out if it's done right... http://www.turbod16.com/viewtopic.ph...t&sd=a&start=0
    Trend settin'
    how about putting in a z6 since it seems y8's dont like you...
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    www.jjspec.com Macon, Ga
    I dont usually shim them. More pressure = more drag on engine which causes hp loss which increases at rpm. Even on my Hot Rod I never shimmed the pump. You can do it but check the oil pressure first to see what you have.
    my momma's house
    Quote Originally Posted by jadakid88 View Post
    Lol, that's probably what I'm gunna do, cause shimming would be the move, but I don't have the porting equipment. Plus, that TOGA is a little too much money for my budget.
    Trend settin'
    Southside Ridin HATCH
    GL homie! when i had the ole Y8 my oil pump went out also.. That when i did my swap!
    my momma's house
    I wish I had the money to do a swap... well, nahhh... I'm hell-bent on this sohc shyit! Throw some DEEZ on dat bitsch!
    Trend settin'
    West palm beach
    i run the stock y7 pump, but i have a oil pressure gauge I monitor very close...
    NO ADVERTISING
    -IA MANAGEMENT
