Results 1 to 17 of 17
Thread: which turbo would you go with GT42R OR borg s300
    Aug 2009
    Default which turbo would you go with GT42R OR borg s300
    Let me know what you guys think . i know the gt42 is like 1200 more but i heard there almost the same.
    the county
    what are your power goals? cause those things are capable of support like 1k hp.
    Flowery Branch, GA
    I love the Bullseye Borg Warners and they are what I designed my rotated kit around for the Subarus. The spool is faster than comparable garretts and they can put out some serious power. What whp are you shooting for?
    ---Mike
    Aug 2009
    hp goals are around 650 to 700
    Flowery Branch, GA
    What car/motor is it? I would guess the Bullseye S366 would get you to those goals. Just give them a call. David is great. I used to use another company that sold the Borg warner stuff and I will never switch. Bullseye has been great and really taken care of me. Customer service is top notch and they will stand behind their products.
    ---Mike
    Aug 2009
    Quote Originally Posted by crashtke View Post
    built gsr
    Flowery Branch, GA
    1.8 liter motor though? Or are you swapping something in?
    ---Mike
    Aug 2009
    Flowery Branch, GA
    The way I calculate it either the 372 or the 374 running a PR of 3.8 and ramping up as you go towards redline. That should put you in the meat of the compressor map. But I would ask David at Bullseye. He has been working with these turbos longer than I have and may have actually put one on a 1.8 in that hp range before.
    ---Mike
    Aug 2009
    Default hey
    well i got the gt42r now and the guy said it had a gt35r hot side. so i was wondering if its gonna be a waste of time to use it
    Privateer Racing!!
    Duluth,Ga
    MY old 42r on gsr motor...
    Attached Thumbnails Attached Thumbnails -turbo2-jpg   -turbo1-jpg
    Flowery Branch, GA
    ---Mike
    Flowery Branch, GA
    Quote Originally Posted by getherdone View Post
    What AR is the housing? If it is a standard t3 housing you are limited to around 700-750 max and that is pushing it to the limits. I honestly would switch to a t4 housing and open it up.
    ---Mike
    Privateer Racing!!
    Duluth,Ga
    Depends on what the use of the car will be... If its a street driven car, keep it the way it is. If not time too upgrade it...
    I love my s372 turbo. It made amazing power at low boost here my last year dyno chart on the gt42r turbo , was about 38psi
    Attached Thumbnails Attached Thumbnails -new-pics-108-jpg
    Aug 2009
    ^^^for some reason i ant see the dyno chart
    Aug 2009
    Default hey
    the cold side says a/r.60 hot side says a/r .70
    Flowery Branch, GA
    .70 would be a great street turbo, and should make 600's I would think.
    On the chart above what is the red run vs the blue one? And why the breakages in the chart?
    ---Mike
