Thread: having problem with throttle body spacer
    stockbridge
    Default having problem with throttle body spacer
    i put in an obx throttle body spacer an now when i crank it up, it jumps idling from1000 to 3000 and back and forth i need help on how to remedy this problem if any one knows i appreciate all input thanks to all of the car specialists that i hope will totally fix it for me or tell me what to do thx
    San jose, CA
    wanna stop posting the same thread in everything you can find go back to genral tech i anwsered ur q
    stockbridge
    Quote Originally Posted by japflipino
    sry for bothering you but maybe someone else has an opinion on what is wrong.....seriously thank you for your help...sry for posting the same thing......word
    San jose, CA
    Quote Originally Posted by preludesi2025
    np didnt try to come out as a jackass
    Banned Jon00's Avatar
    Dec 2003
    Grayson, GA
    blow up the car
    murdahrin dem Blood-Claat!
    I had that same problem. A simple thing to change or check is the map sensor on top of the throttle body.
    stick two fingers into the throttle body, there should be two holes right in front of the butterfly, plug those holes up with your finger... it should kinda suck your fingers into the two lil holes... if the idle goes back to normal.... pm, i;ll tell ya how to fix dat.
    if it doesn;t fix the idle, then forget everything i said.lol
    stockbridge
    i thought that had something to do with it,,, the gasket covers up those two holes....im wondering if those two holes being covered up is the problem?................holler
