Results 1 to 23 of 23
Thread: How much hp at 7lbs on stock GSR could I expect?
    Default How much hp at 7lbs on stock GSR could I expect?
    I was curious as to how much horsepower to expect from a 95 GSR around 130k miles, stock with a turbo, chipped not tuned at 7 psi?
    Around metro-ATLANTA & IA!!
    not tuned maybe 195-205whp with distorted power delivery, not so good dude......230-240whp tuned correctly....if u dont tune your shit...us allmotor guys with only 170-180whp will run you down son...lol just get your shit tuned man...NA or turbo....do it right..THE FIRST TIME...lol
    rockem sohcem robot
    7 lbs outta what? a td04h 15g turbo pushing 7 lbs isnt the same as a gt42r..
    "TheCrew"
    Crew member #3!
    just because I came in late I am leaving one two open haha
    yeah im planning on it soon. How much does it cost to tune? Right now it is running smooth, if it isnt sputtering should I even get it tuned?
    1995 Acura Integra GSR - 133XXX Miles Engine / Internals B18C1 South Florida Performance Manifold T3 .58 Trim? Turbo (Not sure of the brand, bought rebuilt from a college engineer) 2.5” 5 hole flange downpipe Tial 38mm wastegate with 5.bar Walbro Fuel Pump (190LPH OEM) Chipped ECU and street tuned through UBER data 450cc Injectors and resister box Front mount Intercooler -Mandrel bent Charge Piping -Blitz Dual Drive BOV Full Kteller 2.5 cat back exhaust, Kteller muffler
    i got a T3 turbo for sale if your interested...great for stock motor setups....its what your lookin for...!! lol
    T3 TURBO~~~~T3/T4 Flange
    yes, get it tuned...just because it's chipped and appears to be running smooth doesn't mean it's not a little lean or too much or too little timing.
    The Deep South
    Quote Originally Posted by LongLiveH2b View Post
    best advice ever!! +7
    Where Am I
    ^x2 u should expect anywere from 210-240 on 7 psi tuned. But not tuned who knows could be 180-250 and its not going to last long... Tuning is your friend.....
    The turbo has been on the car since 04 untuned. maybe 30k miles since installed because it was not a daily driver. I just bought it so hopefully it will last a little while longer until I can get it dyno tuned. Im curious as to why 7 lbs of psi would vary from turbo to turbo. I mean no matted what size turbo is on the car, 7 lbs of psi is 7 lbs. I mean I know some spool faster then others but thats the only difference. Right?
    Quote Originally Posted by lookitzme16 View Post
    No, the difference in turbos is the actual air VOLUME not pressure. 7psi through a coke straw and 7psi through a piece of 6" pvc pipe.. which is going to be more air??
    Yeah I understand that. I guess I thought it measured boost after the turbo but maybe im wrong. After the turbo it would be the same either way since it would be going thru the same size tubing. I really dont know much about it. just trying to learn now
    Jul 2009
    actually........ 7psi at the intake manifold..... is still 7 psi at the intake manifold no matter how you butter your bread.........now.... many oem turbo setups draw signal psi from the turbo housing........ so there are differences because of turbo a/r and intercooler efficiancy.....ans so on
    later QD.
    Flowery Branch, GA
    Also the density of the air. It could be 7 psi of 250* F air on a turbo that is tiny and struggling vs 7 psi of 140* F air on a larger turbo that is barely breaking a sweat. You gotta keep them in their efficiency range. That is what the turbo calculator I posted is great for!
    ---Mike
    your moms house
    Quote Originally Posted by dallasb84 View Post
    later QD.
    yes 7psi is 7psi but a t25 turbo pushes 750cfm of air at 7 psi
    a gt30r pushes 1350cfm at 7 psi. the boost pressure doesn't mean jack
    that makes a huge difference
    ok I understand that part of it. BUt Im still having trouble understanding why you need a dyno tune. ISnt that what the maf meter and o2 sensors do, is tell the ecu is its running to rich or lean and compensate time to ajust for that? If thats so then why would it matter if you have boost? I just seen a gsr with a stock engine and head running 9 lbs at 325 whp, it was tuned tho so I dont get why an untuned stock gsr would not have somewhere around 275 whp untuned?
    gsr use map not maf and the map and o2 do not compensate for rich/lean and make changes. the only compensation the o2 does is during closed loop operation (emmissions) and that is under lighter loads. wot the ecu fuels/times based on what the map shows. stock ecu doesn't even have any boost tables...it stops @ 0" vac. therefore, if you could keep the ecu from freaking out when it sees boost it would keep fueling the same and timing the same for 0" vac all the way up through how much boost you push=lean and boom!
    even if you have a chipped ecu that has extended tables for boost would be better, but again, since hondas are map and rpm based it's going to fuel based on load at a particular rpm. a map tuned for a baby turbo is going to need more fuel down low and less up top rpms vs. a large turbo is going to spool differently and need less fuel down low and more up top because it's flowing more cfm up top.
    sounds like you're trying to save some $, but doing what you're proposing is going to cost you way more in the long run.
    hope that makes sense.
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    reps for scotty i have a boostd gsr in my da and i have a prob weith it losing its fuel when it hits vtec and a t WOT but if you ease into the throttle and follow it through the rpms and give it more gas its run strong as hell
    INSERT SIG HERE>>>____________________________
    Jul 2009
    Griffin, GA
    as soon as my OT pay kicks in from the dept im gonna get up to mainstream and get it dyno tuned hopefully in a week or two depending on this friday paycheck
    Certified Gearhead neon_ert3's Avatar
    el oh el at that guy ^^^
    lots of good info in this thread
    ridin in a honda
    1990 mazda rx7 TII
    Oct 2008
    brookhaven
    i would get a bigger fuel pump.
    Teglover teglover101's Avatar
    H.C.
    Quote Originally Posted by 91boostdgsr View Post
    Were you at Tanger outlet for Halloween? i think i saw your car.
