Results 1 to 17 of 17
Thread: HELP WITH THE CB7!!!
    rockem sohcem robot
    Default HELP WITH THE CB7!!!
    Ok guys few questions.
    1992 cb7 accord coupe.
    h22a swap manual tranny no ac no ps
    1. no vtec and the speedo is inoperative
    2. the heat doesnt work. welll.. if you turn the fan off and the heat all the way to red and wait like 5 minutes, then turn the fan on low the heat works amazing for like 3 secs then gets cold again.. whats the deal?? i thought it was low on coolant and it was like a third of a gallon low.. before i put that third of a gallon in the heat was completely inoperative
    any help will be repped to the fullest!!!
    "TheCrew"
    Crew member #3!
    just because I came in late I am leaving one two open haha
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    any overheating?
    98 Acura Integra LS-DD
    ??????????????????-project
    AccuracyPerformanceAutomotive
    Vtec...wiring,ecu??
    Speedo...speed sensor, wiring??
    Heater... heater control valve, cable???
    Check those first.
    500whp of spinnin fury!!!
    rockem sohcem robot
    No over heating.
    Cable for valve it fully functioning. Heater control valve doesn't seem to be bad.. Way to test it?
    Can a speed sensor cause speedo and vtec problems since the doesn't think it's moving?
    "TheCrew"
    Crew member #3!
    ..unknown
    I had the speedo and vtec problem in my cb7.
    Most likely it's the speed sensor. Vtec doesn't function if the speed sensor is messed up.
    TALKING ROCK, GA
    Quote Originally Posted by Big_Joe View Post
    x2. as for the overheating problem...heater core? check to see how hot your heater hoses going the the firewall get and make sure there is circulation to the heater core.
    rockem sohcem robot
    The speed sensor was unplugged.. Plugged it back in and it bounced around/ worked ok for about half a mile and now just bounces around 10 when coasting and falls to 0 on accelleration
    "TheCrew"
    Crew member #3!
    I don't know if you are aware of this website or not, but have you ever been to www.cb7tuner.com ?
    If your questions or problems cannot be answered or fixed on IA, try heading over there. Just about every single thing that has to do with any CB7 has been addressed.
    If you need a new speedo, I got 3 accord ones. Cheap as hell.
    rockem sohcem robot
    what do i buy a vss for? its a 92 accord with a jdm h22a and m2b4 tranny
    "TheCrew"
    Crew member #3!
    rockem sohcem robot
    and i asked on cb7 tuner as well
    "TheCrew"
    Crew member #3!
    buy it for the tranny you have, the plugs are the same. check the thermostat, need to check to see if vtec is properly wired. check the exhaust when coolant is full and car is warmed to see if it smells like coolant. that means a blown head gasket.
    About to approach beast mode
    MCD
    Quote Originally Posted by masonhenson View Post
    like said already. you must be over 20mph inorder for vtec to work. so you need a new speed sensor. one from a stock accord will work. like cb7 years. are you sure the heater lines are actually hooked up and not looped or anything.
    neg reps please. thanks
    rockem sohcem robot
    ok so one person says the vss for the tranny, another says for the car. which is it? this morning the speedo worked for about 2 miles and i THINK vtec popped in first. the tranny is a jdm m2b4.. so where do i get a vss for that.
    "TheCrew"
    Crew member #3!
    MCD
    just change the vss first. those are usaly super cheap. thats what mine was doing when i first put my h22 in becauase i accidently broke it mine putting it in. i just used a accord one.
    rockem sohcem robot
    Quote Originally Posted by whatever210 View Post
    will try... any help on how to change one? haha
    "TheCrew"
    Crew member #3!
    MCD
    its on back of tranny and i believe its one bolt that holds it down with one connector
