Thread: multi point conv. last question
    georgia
    Default multi point conv. last question
    does anyone know of a diagram i can follow to just wire my obd0 si distributor straight without the plug,i dont care if you call it a hack job i need it done now and then i will wire it with a connector when i find 1. help
    yes i am....
    georgia
    i just answered it, im gonna use my square plug of the 1.5 distributor and wire it to the 1.6 si distributor since the 5 colors match right up and then run the remaing 2 wires on the si distributor blue/green and blue/yellow to the c1 and c2 spot on the ecu i hope thats right
    yes i am....
    Jul 2009
    are you any good at planting tulips?
    aye bro .:Stirfry:.'s Avatar
    yea c1 goes to blu/g and c2 blu/y..
    but which pin out on the ecu are you wireing up the injectors to.
    ATL DAsquad Member #9
    georgia
    Quote Originally Posted by .:Stirfry:. View Post
    harness A 1,3,5,7 and the resistor box is at 15 on the same harness,the only issue im having is not having the si distributor connector so im gonna try and wire up the 1.5's square connectors to replace the round one.
    yes i am....
    georgia
    what a waste of a day! put everthign in wired it all up and no start! i have a code8 on the ecu im thinking the distributor is bad,so i put all the multi point stuff back did everthing else in reverse ha! damn ebay!
    yes i am....
    Quote Originally Posted by dallasb84 View Post
    semi funny the first time now old
