Results 1 to 22 of 22
Thread: 95 Integra GS-R Died at a red light
    Teglover teglover101's Avatar
    H.C.
    Default 95 Integra GS-R Died at a red light
    So i was coming home yesterday from Barnsville and i got off at Eagles landing and stopped at a red light. When the light turned green i put it in first and started to move when my car studders and dies. At first i think i just didnt give it enough gas, but it won't start now. it will attempt to start but wont. So i got it towed and am having my neighbor who is a honda mechanic look at it today. It has 130xxx on the motor and 180xx on the tranny, header, and CAI. it started perfectly all day so it couldnt be hydrolocked right?
    LMK what you guys think
    Reps for any advice.
    SOUTHSIDE
    Need more info
    Are you getting spark
    Or fuel?
    SwiperNoSwiping!!
    Quote Originally Posted by wrekonize View Post
    Need more info
    Or fuel?
    yeah, first few basic things to check; spark, fuel, air, and timing.
    u remind me of a wigger !
    H.C.
    I will have to check. Didnt get to since it was so late. Could it be Hydrolocked if i have been driving/starting it for more than a day in dry weather?
    SOUTHSIDE
    Pull the plugs to see if there's water if you think it htdrolocked but my guess is that your dizzy coil went out... Is the motor turning over
    Quote Originally Posted by teglover101 View Post
    what reason do u have for thinking it might be hydrolocked.
    H.C.
    My GF lives down a gravel road and there was a puddle yesterday that i avoided as much as i could and ive heard some stories where it doesnt die immediately so i wasnt sure if i could rule that out of possible problems.
    H.C.
    Could a bad ignition coil be the problem?
    02 WRX patrick4588's Avatar
    warner robins
    make sure your timing belt didnt slip a tooth or even break.
    GCO Member
    NRA Member
    warner robins
    possibly
    GCO Member
    NRA Member
    very much so could be the problem, and a very easy fix.
    My line of work
    www.internationaljets.com
    my gsr did the same thing but not at a red light. i was pulling my wires while the car was on 1 by 1 to see if there was spark, as i got to #3 my car turned off. i checked for spark again after it would turn on and nothing. it ended up being the dizzy.
    did you have your CEL light on? mine was on saying i had multiple missfire.
    damn, i want that penis
    Norcross
    my car has done this sometimes. fuel pump dies for a few minutes for some odd reason
    H.C.
    Quote Originally Posted by marcos713 View Post
    No i have no lights on. I talked to the mechanic and he said he is thinking its the ignition coil as well.
    have him the coil before he swaps it out.
    SOUTHSIDE
    do you know anyone with an integra that will let you try their dizzy on your car to see if thats the problem....
    Certified Gearhead vubuilt's Avatar
    ATLANTA
    also check you main relay.
    TACO
    Privateer Racing!!
    Duluth,Ga
    It could be so many things man. My mom was driving my teg and it just shut off on here also. End up being the timing belt. But i would check for spark, fuel if you getting both you should be fine.
    Dont keep turning the car over until you check the timing tough, It could ahve jumped timing and you will mess up the motor. Just my tought!
    have him check the coil before he swaps it out.
    fixed!
    H.C.
    Turns out it was the ignition coil. I also need a basic tune up bad so im getting my the coil and tune up done for $100. Cant beat having a honda mechanic as a neighbor.
    i bet u i can.
    H.C.
    i bet u i can.
    How so?
