Thread: Swapped OBDII Cars Emissions
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Default Swapped OBDII Cars Emissions
    HOw do swapped OBDII cars pass emissions?
    If they are swapped with OBDII motor is it easier?
    What about if swapped with OBDI/0 motor?
    Can they even pass?
    \m/>_<\m/ dorin48's Avatar
    Canton
    If you need to pass emissions with an OBD2 car an OBD2 swap is needed or at least a a swap that keeps all sensors functioning.
    southside ATL
    yup, i got a obd2 with a obd1 swap and cant pass cause it has the obd1 wire harness.
    Sep 2004
    Gwinnett County
    So throwing an LS3 into an S2k would still pass emissions cause both are OBDII?
    Canton
    Quote Originally Posted by IndianStig View Post
    Well........maybe. The emissions guy would have to overlook the fact that the engine is swapped. Most do, but technically its not legal. Its easier for instance with a swapped honda with a honda engine but seeing corvette shining under the S2K hood doesn't help. Also some years (varies by manufacturer I believe) have the VIN embedded in the ECU. So obviously your LS3 ECU wouldn't match the S2k's VIN. The EPA could come knocking though I've never heard of them doing this.
    1-3-7-2-6-5-4-8 40th GT's Avatar
    Suwanee, GA
    Is that your next project?
    :boobies:
    Mine's the red one.
    Sep 2004
    Gwinnett County
    Quote Originally Posted by 40th GT View Post
    :boobies:
    im trying to pick up a g8/gto right now that has a some flood damage right now if the price is in my range and thats the plan if i can get it workin right. or maybe in a 240sx, that'd be cheaper and i'd fit more comfortably.
    Earth
    Dunno, Georgia used to be cool with swaps, didn't care what the motor was just, what came out of the tailpipe. My county doesn't require emissions so I haven't had to mess with it since I moved back.
    Glad I could clear that up for you.
