Results 1 to 17 of 17
Thread: Nitrous Cam Help
    SHP Josh...'s Avatar
    Default Nitrous Cam Help
    I know this doesn't belong here but there are more domestics in here. Ok I have a 93 5.0, stock 97 explorer bottom end, trickflow track heat intake, 24# inj, holley forced induction 255, 3.73 gears, full exhaust, msd digital 6, 70mm tb, 73mm mass air. And I want to put a trickflow plate kit and run a 150 shot, I just bought some pro comp 210's (I know these heads are too big but I don't plan on keeping the 302). And I'm about to buy some pro comp 1.6 shaft mount roller rockers. So, my question is what would be the best cam for me to run, because all of the ones I'm looking at are either too big or they don't have the power range I'm looking for (2,200-6,200).
    *And these are the cams I'm trying to decide on.
    http://www.summitracing.com/parts/TFS-51402001/
    http://www.compcams.com/Cam_Specs/Ca...csid=1051&sb=2
    Anderson N-41 and N-412
    http://www.andersonfordmotorsport.com/cams/cams-50.html
    or an F cam
    Quote Originally Posted by xtquickgt00 View Post
    my car is an automatic my overdrive button wasnt working during the dyno i fixed it afterwards. i live out towards cartersville and me and ted were messig around the hole way to powder springs so he converter was hot also... after i dynoed it i puyt it back to stock and it felt stronger and my wheels bent on the pass. side hell fr what it was ying on th dyno ican still manage to get a 14.00 in the 1/4
    Those cams are too big for a 302.
    Quote Originally Posted by Init2winit View Post
    Reps, and thanks for the help. Is the anderson n-41 too big aswell?
    518rwhp at 10psi
    the anderson N41 will allow you to make 320 to the tires on the bottom end. and so will the F-cam. the trickflow is also a good cam if you had more compression. trust me ive had all three of these cams. on a stock bottom end.
    Quote Originally Posted by Josh... View Post
    I don't like the Anderson stuff. There are a lot better cams out there.
    Out of the three that you posted the comp looks the best, but is that going to work well with nitrous? It looks like more of an NA cam.
    Stockbridge foo
    You semi copied my name..
    Jason..
    Quote Originally Posted by Jason.. View Post
    lol I joined before you.
    All three of those will work well with a small hit, up to 250. Those will give you the best of both worlds.
    Sounds good to me, I'm not going over 150 anyways.
    Certified Gearhead QKJUICEDPONY's Avatar
    Dallas
    Yeah right......Everybody says that but before long you will be buying jets for a bazillion shot
    Here for fun!
    Clapped out Mustang checking in!!!!!!!!
    Quote Originally Posted by QKJUICEDPONY View Post
    Well I know I will want to go faster, I have a lot of stuff to buy before I can start building the motor that will go in its place. This is just to keep me happy during the long build ahead.
    Delete me please
    Apr 2009
    Delete me please
    Have you looked into a custom grind? You would more than likely end up way ahead with a custom grind rather than an off the shelf stick. Try Jay Allen at Camshaft innovations. Google them and you'll find the link.
    Delete this profile please
    Quote Originally Posted by pixyspoxey View Post
    No more engine than he has, a custom grind probably wouldn't have a noticeable difference.
    everywhere & nowhere
    PMd.
    JDM TYTE AnthonyF's Avatar
    He didn't copy your name at all. Your name is Jason...his is Josh. Check your drivers licenses to confirm this.
    -Ant.
    The Carbon Fibered R6
