Results 1 to 14 of 14
Thread: integra blower motor problem
    athens
    Default integra blower motor problem
    car: 92 integra rs
    so my problem is that the blower motor(interior) has completely stopped working. i know why but i cant find a solution.
    the power and ground wires leading into the blower motor touched together and thats when the motor quit working.
    ive pulled out the blower motor, checked the BM resistor and changed it out for a working one, i checked the fuses (they were good), tested the BM to see if it works( it does), and used a test light to see ifi was getting any power on the power wire(no luck)
    so..im not getting any power to the motor. and its hot outside..and ideas or tips would be appreciated..and repped.
    if u got power to the wires but power into the BM. u got a brake in the line from when they touched. find the highest point with power. u will after the brake someplace around there.
    athens
    well im not getting power at all as far as i can tell is the problem. i used a D battery to test the motor i just touched it to the spots on the power and ground wires that were bare, and it kicked on. i tested it like that as far up as i could access the wires.(only about a foot)
    the old man NAIZBST's Avatar
    find the blower motor relay and check power on it...
    pretty much i would follow the path...
    athens
    awesome...thats what ive been looking for, thanks.
    Quote Originally Posted by chip P. View Post
    lol should have asked for it earlier.
    athens
    ive tried to find one. do you have any idea where it is?
    Quote Originally Posted by NAIZBST View Post
    athens
    fixed bisches
    fixed bisches
    where was the failure.
    athens
    i checked the #25 fuse and that was it. it was bad. its the starter relay fuse...weird
    got yah
    that is weird
    i just reread that #25 is for the ignition switch. if that was blown there should have been a lot more than just the blower fucked up.
Tags for this Thread
