Results 1 to 21 of 21
Thread: wire tuck
    JDM-EJ1 shadowx3's Avatar
    G-County
    Default wire tuck
    i need to know where to put the lines that are on the fire wall to do a wire tuck like hide them so you dnt see them where do yall usually put them at?
    you usually run them inside the car.
    PURP-a-trader PURP's Avatar
    yep... behind the dash
    G-County
    any body got pics of how it looks inside or steps that i can follow on doing it?
    I had some of mine but I can't find them
    G-County
    am talking about these lines?
    those are brake lines... those stay unless you have a flaring tool and more lines to relocate. This is how mine is... But it's a full custom brake line tuck
    G-County
    ok thankz for the info bro
    G-County
    do you have any more pics bro?
    not any that would be helpful... and if you've never messed with something like this.. DO NOT ATTEMPT it. Get someone that has ran brake lines. Remember, those things help you not crash...lolol... anything ran wrong will result in failure
    G-County
    thanks bro i wont mess with it then
    Earth
    Listen to the Purp. He knows what he is doing.
    G-County
    yea thanks onces again but any pics of the wire tuck an all that? steps on the wire tuck
    Back from R&D Land
    Back from R&D Land
    http://www.honda-tech.com/showthread.php?t=1693934
    Almost 1000 pages of info here man.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    if its not a show car its not worth it. you loose alot more than what you gain, trust me on this y0!
    Quote Originally Posted by Purple Power View Post
    lol wut... I've done a few tucks.. you lose nothing but wires from the bay.. and gain a cleaner bay...
    Quote Originally Posted by shadowx3 View Post
    To tuck the sections of wires running to your headlights and such.. you'll pull them into the car. get a 1 1/2 inch circle cutting blade thing for the drill. you'll drill right in front of the door. you'll have to remove fenders. get your wires pulled through. extend them as needed. Splicing one at a time. Then zip tie up.
    on the drivers side. There's a plug in front of the door. prolly 1 1/2 x 2 inches. You can pull the wires through that. The passenger side, you'll have to drill a hole.
    as for the main plugs. pull them through, extend as needed, one wire at a time. take the circle bit and drill a hole at the bottom of the firwall dead center. run wires through and plug back in. I have no pics of that.. but might be able to get some later
    RE30
    Here's one me and a couple of friends did. The way we did it, we didn't drill holes or anything. We took out the entire blower/heater core. I don't drive the car in the rain so i didn't care. We ran the wires through that hole and no need for stretch or anything. The headlight harnesses are ran through the fenders. The brakes line are a bit more complicated then we thought so we just removed the abs and left it at that. I don't recommend messing with the brake line unless u know what u are doing. If you still want to do it, make sure you get a metric flaring tool and NOT stardard size. The bay isn't done yet either just close to it lol.
    Bad Luck kID FAM0U5's Avatar
    Dec 2008
    will anyone would like to help me in the near future?
    Quote Originally Posted by xlilvi3tx View Post
    not nick picking... but the way you ran the wires would be able to be seen. You drill the holes to get the harness lower and out of sight. I also, removed both boxes from under the dash and made block off plates. But since the heater core hole sits on a flat part of the firewall, you're able to see the lines. Just preference I guess. But I like all mine hidden. Bay looks good. Should have gotten rid of the fuel set-up while you were at it and also should have flipped the booster to hide the vaccumm(sp) hose from the booster to the manifold. Also, take the ground wire and mount it on the back of the valve cover and mount to the side of the strut tower. Just some helpful ideas. Again, the bay looks good
    RE30
    Quote Originally Posted by GOT_PURP View Post
    Yeh, i can agree with you that it can be seen but just barely. Thanks for the ideas lol I'll be sure to do that when we start working on this thing again. It got way more work to do. Also, thanks for the compliment, same goes for u too
Tags for this Thread
