Thread: speaker cutting in and out
    f-ckouttahere. PROŽ's Avatar
    Default speaker cutting in and out
    if the rear speaker in my del sol cuts in and out(some days it works, some days it doesnt), does that mean that the wiring is bad? or perhaps the speaker is bad? or maybe there is a loose wire?
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Could be a loose wire, loose tinsel lead on the speaker, speaker terminal grounding to the chassis sometimes, a wire that has had the insulation rubbed through to the copper and it is sometimes grounding out. Just have to track down the problem. Too many possibilities to tell you for sure.
    Cumming, GA
    What he said...
    Plus, it could be within the head unit (or amplifier) itself. You can pull the head-unit, and connect a different speaker directly to it....that would potentionally elimiate the existing wiring and speaker.
    What The Hell
    Kennesaw/Acworth
    ever get it fixed?
    i would assume its just a loose wire with how you explain it.
    Quote Originally Posted by 90_ACCORD
    ever get it fixed?
    yea, got it fixed. it turns out that the speakers are just going bad. i changed out the speakers from the front with the ones in the back and it worked perfectly. i thought that if the speaker was going bad, then it wouldnt work period....or it would pop. guess not. anybody have any reccomendations for a good reasonablly priced 6.5" speaker?
    i was looking at the pioneer TS-G1642R (44.99)
    http://www.bestbuy.com/site/olspage....=1199494465847
    the pioneer TS-A1673R (79.99)
    http://www.bestbuy.com/site/olspage....=1218056225571
    and the infinity REF6022I which i saw on crutchfield had great reviews (99.99)
    http://www.bestbuy.com/site/olspage....=1166234894507
    *reps to everyone btw
    up...recommendations on speaker? (post #5)
