Results 1 to 10 of 10
Thread: odd questionn..
    Senior Member cm7k24's Avatar
    kennesaw
    Default odd questionn..
    if im running a stock t25 turbo on my ef.
    could i run it with out a BOV??.
    Canton
    Sure you could but the compressor would self destruct before too long.
    Try not. Do or Do not.
    Woodstock
    What do you mean by a "stock" t25 (internal wastegate I assume)? And why don't you wanna run a BOV? A BOV takes the extra air that is built up and relieves pressure when the throttle plate closes......hints what eraser said. If you don't want the sound youtube them for a quiet one and run it recirculated, it'll be less annoying that way.
    And if a BOV is out of your budget, you shouldn't be boosting anyways
    Save yourself the trouble... run a BOV.
    I ran the passed week with a BOV that wouldnt open, and you'll hate yourself before too long.
    First, you're paranoid because at any moment you expect a pipe to explode, or to see your turbo flipping down the road in your rear view.
    I finally fixed it, and im so relieved. So please, run a bov. Ebay sells a greddy knock off for like, $40.
    kennesaw
    Quote Originally Posted by Slomaro Z28
    oh no its not out of my budget,
    i was wanting to keep my car as low key as possible, similar in a way to a 1.8t. but a blow off valve set it all of rolling down the street.
    lol im just gonna research for a quiet one.
    georgia
    Quote Originally Posted by cm7k24
    do like the guy mentioned above and recirculate it.thats what im gonna do when i finish mine i want mine as quiet as possible .i have used stock dsm bov's for this in the past they work great and are cheap.
    yes i am....
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Quote Originally Posted by THEONE
    What he said. Use a stock DSM. They are cheap, reliable and they can handle a good amount of boost. Just recirculate it and you will be good on the quiet factor. You wont be disappointed.
    Apr 2009
    Quote Originally Posted by TSiFTW
    Just make sure it's a 1g.
    DurtyDubs pebojelly's Avatar
    Villa Rica
    I will give you a VW Diverter Valve,pm me.
    This is what we run on a 1.8t,came off mine.
    You will also need a factory airbox.
    Also not running a BOV will not hurt anything,it will cause turbo lag.
    The BOV does not open until you let off the gas,the vacuum open it and the air is then dumped out of the hot side of the system.
    This then allows you to floor it again and not have to wait to get the turbo spinning like crazy again.
    This is the best reason for a BOV it helps with response and alleviates any delay when you let off the gas to floor it again,
    If you have ever been to a drag strip and watched a real tt car run in the 6's in the quarter you will know you will not hear the first swoosh sound from a bov.
    But again your not trying to drag this all day long,so spend $50 on ebay they are fine and go play.
