Thread: Compressor Surge problem
    Default Compressor Surge problem
    I changed out my BOV because my old one started leaking at the valve.
    I went from a Turbonetics Raptor BOV, to an Ebay BOV. I know its cheap but im only running 12psi at most.
    After install i took it down the road and had Surge (shutter). So i brought it back and loosened the adjustment screw. Same story, repeated 4 times. Now the screw is as loose as it will go.
    The only other problem with the car is that my Flex section has a fair size hole in it. that will be replaced within 2 weeks.
    Do i tighten the bov?
    dc5
    ATL, GA
    is there a replaceable bov spring inside?
    You want to run the bov spring accordling the your vaccum range of your car..
    Like on mine, I need to run a 7 or 9 psi bov spring inside.. It came with a 11 psi spring.. If I used the 11 psi spring, it would surge at part throttle...
    How do i know what my vaccum range is?
    so i can jst take my spring from the turbonetics and put it in the ebay?
    known as Charles
    What ebay one did you get? If it is one of the Greddy lookalikes then they normally come with 2 springs inside. You can take it apart and only run one of them.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    It does look alot like a greddy, except red on top instead of Purple. (I figured if Im going to get something cheap, at least make it match my catch can/strut bar)
    Charlie is the man!
    Took it apart, and just as you said, 2 springs interlaced. I took the small one out, put it back together, and tried it. It was still too much. Switched to the small one....BINGO!
    now, it doesn't sound as clean as the turbonetics, but its doing the job. now i just need a flex section and i'm back to running smooth.
    i had the same problem with my ebay bov. so i just threw it away. i wish i would have known it was that easy. lol
    new project every week.
    IA's Pedo-cord tdurr's Avatar
    Fayco
    soooo tandem?
    Save ur engines!
    MCD
    Quote Originally Posted by tdurr
    soooo tandem?
    sure?. this tues?
