Results 1 to 40 of 40
Thread: overheating/ no heat
    PEENGONE Hektik's Avatar
    Default overheating/ no heat
    98 civic lx.. completely stock d16y7..
    when i bought it, it didn't have a thermostat so i put one in and bled the system about 7 fan cycles.. the radiator cap was a discount auto parts 16lb cap so i changed it for a 13lb cap. no luck...it will run fine for a while as long as im not going above 3.5 to 4k RPM. also had a misfire code. on cylinder 2 and 4 and a random misfire code... both top and bottom hoses feel hot to the touch. when it starts to overheat it will bubble out of the reservoir.. after it overheats the car wont start i ussually have to jump it... also the hose from the reservoir to the rad was getting kicked of when it would start to overheat so i put a clamp on it... the heat will not work... i did an oil change and the oil seemed fine except it was really thin... no milk on the oil cap but when it overheats the cap seems to get a greyish film on it very thin but a film non the less.... the coolant in the rad doesnt seem to have any oil in it.. but the reservoir seems to have oilresidue on it....fan kicks on fine
    so im thinking it most likely will be the headgasket.... but im open to sugestions..... heater core maybe...im really trying to stay away from having to crack the head open....
    excuse the long post, just trying to give as much info as i can....
    AccuracyPerformanceAutomotive
    Quote Originally Posted by Hektik
    Def sounds like the headgasket.
    500whp of spinnin fury!!!
    hg all day
    Norcross
    put a vtec head on it since u have to replace the hg
    ^x2! Definetly !
    damn, i want that penis
    JDM TYTE AnthonyF's Avatar
    hg all day
    What if he drives at night?
    -Ant.
    The Carbon Fibered R6
    Where Am I
    Quote Originally Posted by j0nbunklah0m
    preciate all the replies guys..
    so i went ahead and got the head gasket, water pump and timming belt.. hopefullly this will fix it...
    no vtec head.. its an automatic daily.. so no point...
    one quick question once i remove the HG should i take it to a machine shop and have it resurfaced or anything like that...
    YES, it might be warped some. And if you dont youll kick yourself in the ass for havin to do it twice.
    -Ant.
    lol yah drive at night problem solved lol it makes sense.
    yes and head bolts. some say reuse the old. for me to risky get some new 1s. just an fyi arps normally are cheaper than oem.
    cool thanks..... ill post up if i run into any problems... or when im done ...lol...
    Thats a good thing to remember.... ill be sellin ARP's with HG repairs now. LOL thanx.
    good info.
    Norcross, GA
    Check the welds on your intake.
    Quote Originally Posted by QWK D16
    no joke thats what i do. most of my customer are everyday people who just dd there cars. an i still use them a better, cheap, more reliable, and reusable product than oem so y not.
    where can i get some ARP bolts locally?
    most honda performance shops. i just hit up summit in mcdoungh.
    Head is warped
    stock OEM headbolts can be reused
    I have done 1,256,2458 headjobs on hondas with not 1 issue even at the dealer we use the old bolts
    Head is warped
    if the head is warped can it still be reused if i take it to a machine shop
    yes they will shave it for around 30-40 bucks and clean it... Then your good to go..Install all new gaskets and seals
    adjust the valves also
    Head is warped
    i dont think we will ever see eye to eye on this one. me personally dont think it worth the risk.
    Ohio asshole.
    For a DD I usually wouldn't worry myself, until this past winter. While the snow flew, I was slapping together a motor for a friend who swore up and down on his stock head bolts. That was, until I did the unthinkable to him, and grabbed the torque wrench and broke one off. I dont recall the specs off the top of my head, but I was only half way to being tight.
    Now, he's got ARP's in his motor
    The head doesn't ALWAYS get warped either. Its typical and a GOOD probability, but not always the case. In the same sentence, NEVER put a HG in an over heated motor with out having it checked though. If its still no good after being decked, then your block is probably warped.
    Quote Originally Posted by jmmx258
    You can check them yourself... Guess noone knows how to use a straight edge and a flash light huh... lol
    Plus a shaved head depending on how much it was shaved can gain alittle hp also over stock lol
    West palm beach
    x2
    Ohio asshole.
    It'll really only add a little more bottm end torque uppin the compression. I have a marble bench I use for checking whether things are out or not
    The problem why people have problems with installing stock headbolts after a headwork is due to them not oiling them and finger tight them so they dont cross thread other then that stock OEM used honda bolts work just fine...
    Ohio asshole.
    I dont have a problem with OE bolts. THe only ARP thing i ever really bought was extended wheel studs for a different look on steelies.
    OE head bolts hold up just fine, as you said, as long they're put in right. I'm a FIRM believer in any kind of assembly lube. I prefer Royal Purple, in every aspect of it.
    My honda head bolts I only dip them in fresh motor oil... Been doing this for years without any issues ....
    Ohio asshole.
    As long as they are new, i wouldn't have any doubts that they'd work. When I do a motor build though, I generally buy a good assem. lube.
    ALL haynes,dealers,alldatapro , michell, all state to use oil on the head bolts. NOT assmeble lube... But both will work just fine...Assemble lube just cost more.
    BTW we are talking about installing headbolts not rebuilding a motor get back over here in the right conversation
    will i need to replace the cam seals?
    and why is there no heat?
    yes cam seals, no heat because there is only air in the system now
    cool preciate it...
    anytime!
    how long should i let the car cool down before i start opening it up.
    u can start when its hot. by the time u get to the head it should be cool.
    could a cracked exhaust manifold cause a car to overheat...
    i started to pull things apart and the exhaust manifold was cracked right where the o2 sensor plugs into all the way almost to the bolts....
    no
    Depending how hot its been getting you might want to let it cool overnight that way you dont strip any of the bolts
