Thread: what is it called
    Gwinnett-Grayson
    Default what is it called
    ok, i need something that will take of this like grunge crap that has built up on the black molding around my windows on my car, does anyone know anything, and also wats a good thing to clean off the build up on my head lights?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    i'm not sure, but your best bet is to go to any autoparts store and check out their detailing section. Sorry i dont know but im sure someone there will
    Gwinnett-Grayson
    yeah that shit doesnt work, im looking for shit to get this gruns shit off thats like built up on it, it wont like come off
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Rock the 40oz GTScoob's Avatar
    GA Tech
    gunk on the molding? maybe some soapy water and a scrubbing pad.
    Headlights, try some cleaner wax, or go buy some Meguir's Plastix(assuming you have plastic/Lexan headlight lenses). Wax on, wax off and you have crystal clear headlights.
    02 WRX Sport Wagon
    Gwinnett-Grayson
    stock shit, i dont know wtf the type of plastic it is, and its like a build up of shit on the molding
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    down the yellow brick road
    its called...........................................
    YOU ARE GAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    LarryTown, GA
    If it's textured plastic molding (you can feel the texture if you run your fingers across it), the best stuff I've used is called GR40. It might take a couple applications but it does remove wax and polish from plastic molding. Check it out here: http://www.topoftheline.com/trim-cleaner.html
    If it's painted molding (like flat black or semigloss black), you can try a wax and grease remover. 3M sells a very good product you can get at WalMart or most auto parts stores.
    As for the headlights, as mentioned already, a plastic polish like Meguiars PlastX will do the job but it might take several applications and a lot of rubbing. It's a good product, just takes some elbow grease.
    __DailyGrind
    hahahahha...that drifting video wit the golf carts crack me up...lol
    Apprentice Signguy
    Dacula, GA
    The best stuff is called "Desolve-It"
    Sold at Wal-mart only like $4. i use it daily when removing 10 year old decals that have built up a gunk and tarr on body and paint. it is safe for the body and not harmful to anything. it is a grease base material. best thing to do is spray it - let it settle on the "gunk" for a couple of minutes then take a flat surfaced. clean edged hand tool (ID card or something) and scrap at the "gunk" it will come off so easily. then just wipe down the area and spray the area with windex or alcohol and is a nice clean surface with no gunk or harm to your body/paint/windshield.
