Results 1 to 15 of 15
Thread: engine swap
    yuuummmyy
    Dec 2008
    Default engine swap
    is engine swap fast? also, does anybody knoes how to do it? and how much would you charge?
    "Bacon And Cheese"
    We can do any swap you need. Let me know. 678-363-6789.
    And what do you mean is an engine swap fast? Can it be done fast, yes. and Depending on what motor it can be quick .
    more info dude.
    What car and what swap?
    yuuummmyy
    Dec 2008
    sorry for a 1995 acura integra. Ls motor. take out and put another one back in.
    Quote Originally Posted by Arm&hammer
    more info dude.
    "Bacon And Cheese"
    SOUTHSIDE
    2-3 hours average....
    yuuummmyy
    Dec 2008
    to take the old one out and put a new one in there? also, it would be nice if i get a brief summary on how to do it.
    Quote Originally Posted by wrekonize
    "Bacon And Cheese"
    Quote Originally Posted by BAC
    unbolt the old, put it, drop in the new, and bolt it in.
    yuuummmyy
    Dec 2008
    can you explain that in a easier way.
    "Bacon And Cheese"
    pull old install new. simplest it gets.
    take axles out
    unbolt linkage, exhaust, ps, ac
    unbolt motor
    take trans off
    put trans on new
    bolt everything back up
    DC5-R
    Gwinett
    If you never done it before, then take it to someone that knows what they're doing. Either that or pick up a helms manual and start reading.
    Norcross
    where are u located?
    North Augusta, SC
    Quote Originally Posted by NoWAyItZTOMmY
    take axles out
    unbolt motor
    take trans off
    put trans on new
    Why would he take trans off and put new trans on for a motor swap? Why you got to change the trans?
    Back to being stock and slow
    Quote Originally Posted by Motivation
    if its a manual he is correct trans will have to come out or be dropped.
    it's pretty damm easy, It's like taking candy from a baby only if you have all the necessary tools
    you'll need
    10mm
    12mm
    14mm
    17mm
    19mm
    32mm for your axle nut
    pliers for some stuff
    needle nose
    axles comes off
    rear mount
    passenger side mount
    driver side mount
    ac side mount
    tranny side mount
    3 plugs harness side of passenger
    3 plugs harness on driver side
    3 ground wires, tranny & valve cover, near thermostat housing
    knock out the gator tooth that holds the shift linkage i use a 3/16 to knock it out with hammer & 12mm
    take off 2 12mm bolts that holds the slave cylinder
    header to catback bolts believe it's 14mm 2 of them
    take out radiator, for more room to work
    and them boom boom poWW engine hoist that bish out and take off
    you should be able to knock this out in 2-3 hrs 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
