Thread: need some help with my ls turbo civic
    Default need some help with my ls turbo civic
    ok im wondering what could be casusing my car to smoke when i slow down after going around 80 or just coming to a stop period. its not alot of smoke but it still has me worried. it doesnt do it when i put it in nutral
    ballin on a budget hondalover00's Avatar
    ga
    what color is it...what it smell like
    looks a little white and smells like oil. mu buddies car does the same when he slows done he thinks its the head gasket but i had 195 across
    known as Charles
    If it does it when you use the motor to slow down (pull lots of vac) then it may be your valve stem seals. If it does it at idle also it could be your turbo seals. Do you have a restrictor in the turbo. Also, you can pull the down pipe to see if it is wet inside, then pull the manifold and see if the exhaust runners are wet. This will help tell if it is turbo or motor.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    the piping has no wet stuff in it. i have a sc61 turbo and it does not have a restrictor. ut never did it on my other motor and it doesnt smoke at all at idle... how can i tell if its valve stream seals and is there away to change them without taking the head on if its them
    AccuracyPerformanceAutomotive
    Quote Originally Posted by Main Stream
    x2 sounds like valve stem seals. Turbo seals will usually smoke constantly.
    500whp of spinnin fury!!!
    how hard is it to change them?dont feel like ordering a new head gasket lol.
    Quote Originally Posted by JDMteg08
    You can charge air into the cylinder, to hold the valve closed and do them one at a time.
    ^^^ know of any links to look at to do it
