Thread: NEED SOMEONE W/ EXCEL SKILLS WANTING TO MAKE SOME MONEY...
    Don't ya like clowns? Paul's Avatar
    Feb 2001
    Default NEED SOMEONE W/ EXCEL SKILLS WANTING TO MAKE SOME MONEY...
    I NEED SOMEONE TO EITHER CREATE A QUICK MACRO OR JUST FIGURE OUT A WAY TO DO THIS W/O MY INTERVENTION. I NEED THIS DONE ASAP AND I WILL PAYPAL YOU MONEY UPON COMPLETION.
    BASICALLY...
    I HAVE A EXCEL FILE W/ 3 COLUMNS:
    PART#(COLUMN1,(20CHAR)), ID#(COLUMN2,(20CHAR)), DESC(COLUMN3)...
    Currently column3 has random amount of characters depending on description, i need this column broken down into 45 char max with the remaining characters made into a separate record using the same column1/column2... it would probably be helpful to create a unique id for every record or number the records.
    example:
    12345, 67890, blah blah blah blah blah blah blah blah
    i need it to be:
    12345, 67890, blah blah blah blah,12345-001
    12345, 67890, blah blah blah blah,12345-002
    if you can do this PM me ASAP
    Paul "your bullshit makes the flowers grow"
    right behind you...
    um i understand the 1st part of your request just fine...up until:
    "with the remaining characters made into a separate record using the same column1/column2"
    Feb 2001
    i need the data broken into separate records b/c the DB system this is going into has a 50 char limit - meaning if the 3rd column has 100 characters it would need to be put into a separate record and that record still needs the appropriate column1/2
    Ghost AirMax95's Avatar
    On a Plane
    Can you PM sample data?
    right behind you...
    Quote Originally Posted by AirMax95
    Yes joecoolfreak's Avatar
    Austin, TX
    Solution sent
    Gainesville
    bastard i was about to make it
    Feb 2001
    i sent the file to couple people first to do it gets $$$
    right behind you...
    i didn't get it
    Feb 2001
    obviously you didn't read directions PM me... i have someone working on it now anyway
    right behind you...
    hater hope they send you back an excel file w/a virus
    Gainesville
