Results 1 to 23 of 23
Thread: Batlground: Custom Intercooler and Piping
    Hand Built Self Made batlbrandon's Avatar
    around
    Default Batlground: Custom Intercooler and Piping
    We started this project on Mon. We took a Garrett intercooler core (14 x 22 x 2.75) and fabricated the end tanks, inlet/outlet tubes, associated piping, and mounting tabs for a customer. This intercooler fits behind the bumper beam and requires NO TRIMMING of the bumper cover.
    turbos
    Whats the cost on something like that..............
    I could use a better intercooler for my civic
    TOO BIG
    West palm beach
    Quote Originally Posted by seanrg1116
    X2
    NO ADVERTISING
    -IA MANAGEMENT
    Certified Gearhead SleepingTalon's Avatar
    Alpharetta, Georgia
    Just call the shop to get the correct quote. It's easier to get a hold of someone that way.
    Stang Mod slostang's Avatar
    Southside
    turbo s197? nice!
    Beautiful! Ever combined multiple cores?
    around
    Actually we are doing a custom set up for an IS300, that will be 2 cores stacked so inlet and outlet are on the same side.
    Costs will vary based on size and application. If you would like a quote please call or email.
    Senior Member Maki's Avatar
    Alpharetta
    hmm i have is300, sounds interesting, post pics, i might be interested
    Quote Originally Posted by batlbrandon
    Weird. Now that I don't come to the shop, I don't know all of this stuff. What does 2 cores do? Make it cooler (as in cold not kool dude) or sumpin?
    Val for president!
    Facebook.com/TracyATL
    I Have a Cool Car chnco's Avatar
    Jan 2003
    Marietta, GA
    2 cores = Twice the volume and surface area.
    Twice the volume and surface area = cooler charge = bigger pressure drop = more power = maybe a bit more lag (minimal)
    This is common sense Tracy
    Summit Shiloh Crew
    Allen C.
    [email protected]
    S13's are the FUTURE.
    Quote Originally Posted by chnco
    I only know what I am told when it comes to cars. I figured cooler, but gawd. Meanie.
    Val for president!
    Alpharetta
    2 smaller cores added together could be the same as one big one, depending on fin arrangement pressure drop could be minimal. you have to weigh which is going to be worse, the pressure drop and friction from more elaborate piping bends or more core which also causes the same. depending on quality of cores it might be smarter. we shall see
    Quote Originally Posted by Tracy
    Mostly to acquire the shape and size you need, and as Brandon said it's enabling the inlet and outlet to be on the same side in a certain place.
    This is two Iveco truck intercoolers that were joined together then welded up with custom end tanks. Total size is 42.5" x 9.8" x 5.5".
    everywhere & nowhere
    Man look at all that slag!!!
    LMFAO ---- j/k --- hotness. Always doing good things over there kiddos.
    Alpharetta
    OMG thats huge
    Quote Originally Posted by Maki
    OMG thats huge
    875 hp @ 5000 rpm & 932 lb-ft @ 3900 rpm
    Alpharetta
    good point..... still...... wow
    CruzanConnection LSVTEC92's Avatar
    !!! In My Back Yard !!!
    is that enough interkooler?
    POSITIVE IS HOW I LIVE ST.CROIX U.S.V.I
    around
    Whoa that is massive. I wonder how much it weighs?
    Are they side by side? theres no seam.
    That and I'd be worried about something hitting it! Would suck to have to replace it because of a piece of tire or whatever!
    Quote Originally Posted by Drummerboy
    Unfortunantly they are front to back. I couldn't imagine attempting to weld an intercooler core side by side! I'm 99.9% positive there would have to be a small tank in-between joining the two if someone were to try.
    http://www.kilander-racing.se/
    Attached Thumbnails Attached Thumbnails -pict0361-jpg   -pict0366-jpg   -pict0367-jpg   -pict0370-jpg   -pict0358-jpg
    around
    I know that thing weighs a hundred pounds!
    It helps keep the front end down
