Results 1 to 40 of 40
Thread: ** EF w/ B16a2 swap misfire help! **
    Default ** EF w/ B16a2 swap misfire help! **
    So we recently put a B16a2 in my hatch, got it wired correctly, runs awesome... vtec works great etc.... but it has this little issue...
    when i first start it in the morning, it sputters and sounds like its misfiring.. but when i clear it out (rev it up) for a second.. it goes away... what could this be?
    reps for any good help!
    Da Nastyist Whipz Member #9
    bad spark plugs
    ^^ are you sure sure? ive never seen this prob before
    Quote Originally Posted by Terror
    im not saying that is exacly the problem, but im sure it wouldnt hurt to pull one or two out and look at them
    in dabuilding
    Quote Originally Posted by Purple Power
    bad spark plugs
    there not bad plugs they were actually never used before i sold him the motor they were pulled out of the box i checked the gap put some anti seize on them and tightened em down so the plugs are good moe but maybe the wires those were on there when i got it from justin
    General Tech Hater
    or better yet, could be a blown head gasket.. after you cut the car off, coolant seeps into the cylinder(s) and when you start it up the next morning or whenever, you have to rev the car until you burn the coolant out of the cylinder.. IF you had a blown head gasket..
    so when you say sputtering... when you first crank it, does it sound like a WRX?
    ^^ It sounds like either... 1 its not getting fuel... or a slight misfire on maybe 1 cylinder... i dont beleive its the head gasket... the oil looks good.
    General Tech Hater
    whoa my friend, it wouldnt run if the oil/coolant mixture was bad enough to be seen in the crankcase.. im sure while its doing all this sputtering in the morning its smoking too am i right?
    AccuracyPerformanceAutomotive
    It could have a fuel injector leaking by when you turn the key on, then when you crank the car up it takes a second to burn out the extra fuel. I had an older accord do this at the shop.
    500whp of spinnin fury!!!
    ^ what i mean is I truly doubt its a blown headgasket, no it doesnt smoke either. Is there a way to test for this? or an easy way to find out?
    Quote Originally Posted by QWK D16
    This seems more plausable... it literally sputters for a split second, if I tap it to 3k once, it stops
    You can pinch off the fuel supply line and have a buddy crank it, then slowly remove the pliers (or whatever) and see if it runs smooth right away, or still sputters.
    in dabuilding
    yea man the injectors did leak a little if u messed with them so that could be the problem but they were like that when i got it from justiin since i never really messed with taking it apart
    Whats interesting is it only does this if its been sitting for awhile.. like over 2 hours... hmm
    They may seal better hot, then leak when they cool down. Or the temp in the engine burns off the leaking fuel until it goes under a certain temp.
    Quote Originally Posted by dabuilding
    More than likely its ur problem. But Im just tryin to give you something to look at next.
    thank you qwk, you have been very helpful.
    I think a friend may have a spare set of injectors for his B20, would they work? or do i need to source specifically... b16 injectors?
    Chickens Eat Eggs
    south side hoe
    check to see if u have the spark plugg wire order right on the distrubtor and to the head
    Chickens Eat Eggs
    south side hoe
    i had 2 pluggs in the wrong order on the cap, jus trying to help
    Woodstock, Ga
    moe i told you cylinder 1 injector clip is not made for that car. you need to go get the right injector clip then we will fix it.
    ^^ this is true, but after ryan looked at it, he told me the clip, although for an ls, it connects fine. It would have to be something else they said... a leaky injector would make alot of sense though
    EE OG Revmaynard's Avatar
    So who's b16 EF is faster, yours or Charlie's?
    Bozzio for president.
    in dabuilding
    ^haha x2 i wanna see that one for sure
    Woodstock, Ga
    lol try to use a injecter cleaner and if it dont fix it then idk lol
    ccw replicas
    kennesaw
    shit mine is way faster, we ALL know this
    HF
    Woodstock, Ga
    ^^^ lmao negitive...
    should bring it to us, can fix
    crappy cold start can mean o2 sensor, regular tune up , etc.
    My b16 in my EF does the same thing, first couple of seconds when you crank it up it runs like shit, hit the gas it wants to die, then it cleans out an runs fine.
    ^^ what i noticed today was interesting... when i start it up it kind of sputters a bit.. and will continue to sputter (rough idle) until i bring it up to 3k real quick. whats interesting is it will stop right away when i get to 3k, right after i start it up... or even if i let it idle for 30 seconds first.
    Woodstock, Ga
    oh yeah moe... i forgot to tell you. it did the same kinda thing when it was in my car. but its because it runs with no o2 sensor. so i guess we can wire it up for an o2 and see if it will help.. just saying.
    ^^ thanks man, idk though... i mean its possible but it really seems like a slight fuel prob.. and the injectors do leak a little dont they? or one of em does?
    Woodstock, Ga
    i never messed with the injectors.. jon might have but we didnt do anything to them.
    try to sea foam the engine, see if it helps
    ccw replicas
    kennesaw
    Quote Originally Posted by You_Wish
    how are you gonna say negative?
    HF
    Quote Originally Posted by csmiths
    cause he knows I have the most ballinest hatch...
    lol jk
    TQ wins races.
    When you crank it, when it studders, let it run at idle for a few seconds then shut it off and pull the plugs out quick and see if one or more is real black. Check the gap on the plugs too.
    ^^ Ill do that tmr, that would prolly be a good indicator.. thanks man
