Results 1 to 20 of 20
Thread: sr20s dynoing over 400
    Columbus GA
    Default sr20s dynoing over 400
    Anyone in the Atlanta area have an sr20 dynoing 400+? give some build specs?
    bringing one out very soon, gauging my dyno expectations.
    MCD
    Quote Originally Posted by Sinfix_15
    real close if not almost there. 550cc injectors with g2871r with .64 side on 20lbs. a greddy fmic, greddy cams, full apexi exhaust, tuning safc2 but if i tune with power fc then im sure ill be over 400. i tried to stay under 400 only so my motor will last longer and i wouldnt have to upgrade to head studs and cometic head gasket. um greddy pro b spec 2 boost controller. that helps with a quick spool i think im full boost at 3700 rpms but over all bone stock internals except for the cams.
    Columbus GA
    Quote Originally Posted by whatever210
    im about to bring the 240 out, running the same turbo g2871r .64, hks 264 cams, cp pistons, 740cc injectors, arp head studs, cometic gasket, aem boost controller, ect. expecting 400+ @ 25 psi, will soon find out.
    THEBEARJEW
    none of your fucking business
    stock bottom end, hks headgasket, arp headstuds, greddy rocker arm stoppers, hks cams, aem ems, 740cc tomei injectors, greddy knockoff intake manifold, gt35r, peak boost manifold, 4in trust exhaust, tial 38mm external wg, 3in dp made 424whp on mustang dyno 26lbs
    could have made more but ran out of fuel thanks to the stock fpr
    buford ga
    ^ ewww how about just build a ka-t its cheaper and you will be more impressed when u start to pull on ppl 413/434 on 22lbs on a 50trim at that lol!!
    MCD
    Quote Originally Posted by stay_up
    another ka-t fan boy
    abcdefghijklmnopqrst afwfjustin's Avatar
    Just turbo your s2k. I made 400 on only 11psi with my old one. F20 makes sick power under boost.
    New car:
    95 S14 with RB25DET (stock boost)
    Old car:
    Turbo S2000 400hp/285tq on 9:1 comp & 11psi
    Hand Built Self Made batlbrandon's Avatar
    around
    We have built a number of 400+ whp SR20Det's (and a few 500+). In our race/drift cars we were making 440whp on the stock crank, pistons, and rods. Never had a melt down in 3 years of professional track time and hundreds of hours on the amatuer circuit. Any which way you would like to go with your SR we can help. What would you like to know?
    edit, please delete. WTF?
    Val for president!
    Facebook.com/TracyATL
    Over 400 all day for several years.
    I think this is an old dyno chart, but here it is anyways and here is the set up at the time of this dyno chart. Full Race Turbo Manifold, GT3076R, Tomei Solid Lifters and Cams, Nismo Injectors, Greddy Intake Manifold, Ported Cylinder Head, Tuned With AEM EMS @18psi
    edit, how do I remove the big ass pic? Has IA changed things or am I crazy?
    Attached Thumbnails Attached Thumbnails -paintingpepept2-007-jpg   -normal_pepe-jpg
    Val for president!
    IA KING
    your crazy..
    Quote Originally Posted by admin
    your crazy..
    Ok, so we can delete our own posts or not? I swear at first I couldn't edit the pic!!!!!!
    Val for president!
    around
    That is an old dyno chart, that was without the head work. And, um, yeah, you are crazy.
    Personally I don't think a 2871r .64 or even the .86 is the best set up for 400whp. You are going to be really working that turbo to try and squeeze it out. You could do a 3071r not lose spool and probably be really close to 400 on pump.
    about this far.
    pshh your car 400? HA
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    about this far.
    Quote Originally Posted by Tracy
    why is there a gap in the power lines?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Quote Originally Posted by callmetree19
    Not sure, maybe the dyno lost signal for a second? Happens sometimes, I think.
    Val for president!
    530TQ + FWD = FAIL!! Kason23's Avatar
    Rockmart
    Looks like a lost signal on the plug wires. I have had that happen before. Its no big deal
    Neon PoWa
    Now Delta 46 equipped
    432whp/425wtq on lower boost
    Quote Originally Posted by Kason23
    Those are really old charts. I will look for a new one.
    Yeah dan made around 430whp right before Nopi 2006. Gap in the chart is just a lost tach signal, thats it
    buford ga
    tracy didn't bucky paint that vc? I was just curious as to what happen to the stickers.
