Thread: what is the differance in thermostat temps?
    Scottish Scotsman's Avatar
    on the road to recovery
    Default what is the differance in thermostat temps?
    i need to replace mine and they have diff temps , 170 180 192 , could i please get an explanation on why they have the 3 diff ones , and which one should i get? (93 prelude w F22B1) thanx in advance
    Stang Mod slostang's Avatar
    Southside
    the temp ratings is basically when the thermostat pops open. i personally always use the coldest one available just to keep the engine a little cooler.
    Doing so will decrease fuel mileage slightly as well.
    Quote Originally Posted by X-Runner
    and sometimes make the engine skip a beat also.... Because some need to run OEM temps or it will run richer ...
    If its OBDII it can kick a check engine light on (CEL) for operation temp below spec
    170 is normal temp for hondas
    its just when you go to Autozone they have other listings, because if you lived in Alaska you want to run the 195 .. But out in GA you run 170
    Hope this help I am drunk!
    sooooooooo 170?
    yup
    OEM specs is the correct answer, Scotsman.
    West palm beach
    Oh Jesus....
    NO ADVERTISING
    -IA MANAGEMENT
    lolol
    AccuracyPerformanceAutomotive
    Use the OEM t-stat.Your car needs the temp to go into closed loop. Or your ECU will set a code.
    500whp of spinnin fury!!!
    www.jjspec.com Macon, Ga
    What ever your car is tuned for and if it is a factory ecu then you should use the factory temp themostat.
