Results 1 to 20 of 20
Thread: Doncha love A/C questions? AC smells liek piss
    clayton county
    Default Doncha love A/C questions? AC smells liek piss
    96 Honda Accord: the AC smells like piss when it blows. why and how to get rid of it? i dont want to know how to mask the smell; i want it goneeeee
    I give out reps....
    EF Squad
    try changing your filter?
    theres a fridge freshener that you can spray through your outside vents, it clears it right up and smells cool! 8D you would need to run your ac on high and spray the stuff onto your outside vents. Which is covered by your hood when you see it .. hope it helps any, and i'm not quite sure what brand and name the bottle was but i got it from Goodyear!
    /Oo ___A___ oO\
    |=_/_______\_=|
    clayton county
    Quote Originally Posted by Tensa_Zanget
    reps.
    I give out reps....
    clayton county
    Quote Originally Posted by VickNotic
    i think this is MASKING the smell. thanks though.
    I give out reps....
    clayton county
    ttt again because problem is not solved. there is NO cabin filter for 96 accords!
    I give out reps....
    Sounds like you have a leak somewhere!!!!!!
    window seal,door seal something is leaking....
    what u are smelling is mold. its living in your evap. if it spread past there u can try to put the heat on full blast for awhile. it will kill the smell but the mold will still be there.
    i'm a got dang wallaby!!
    someone pee'd in your vent.
    also, frigi-fresh is a possibility, i'd also check into lysol the heater box, exterior and interior vents.
    could also be a mouse nesting in there (the relieve themselves where they sleep and eat). it happens a lot when it gets colder outside and/or if your car is outside most of the time...especially at night and for extended periods of time.
    spray into the vents, put the a/c on hi fresh air, spray the outside air intake at base of windshield, and don't be afraid to use too much. then put the ac on hi rec and spray @ the inside air intakes (usually floorboard areas). the lysol will kill mold/mildew, and any viruses the mice transmit/carry.
    dryer-sheets under the seats and near the inside air intakes will keep the car smelling fresh.
    drop the blower fan and clean it out, and clean out whatever you can down there while your at it.. spray oust everywhere
    Hwy 315
    correct sir, also might want to remove your wipers and pull the windshield trim off to clean out that area. I bet you have stacks and stacks of leaves built up, which, when composting emit all kinds of cool smells. While you've got that open, hose down the climate control fan while it's running (you'll see it) with some lysol - it'll kill the mold in throughout the system as it circulates.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    I hear know one telling him it might be his body odor
    Also try a foaming evaporator cleaner
    IF you drop the fan motor you should be able to clean off the intake side of your evaporator while its out without having to break open the a/c.
    Quote Originally Posted by ASE*Tech View Post
    clayton county
    Quote Originally Posted by Purple Power View Post
    yes come do it.
    I give out reps....
    no, too busy
    Hwy 315
    Or...
    it could be that you haven't taken a shower in a few days.
    Axe - get some.
    just a thought.
    -jonathan
    [/URL]
    clayton county
    Quote Originally Posted by ash7 View Post
    Or...
    Axe - get some.
    just a thought.
    -jonathan
    lol that's pretty lame.
    I give out reps....
