Results 1 to 5 of 5
Thread: T-Rex 450 / HDX 450 SE V2 Electric Radio Controlled Helicopter. Ready to Fly!!!!!!!!
    Default T-Rex 450 / HDX 450 SE V2 Electric Radio Controlled Helicopter. Ready to Fly!!!!!!!!
    $999 OBO
    READY FOR SUMMER FLYING!!!!!!! Please email [email protected] for any questions you might have.
    I am not much of a flyer I am more of a builder and a tinkerer. I drove a nitro truck recently and decided I want to get rid of my helis and get more gas trucks. This is the last one I have left. It flies great and I have just hovered it and flown it forward backward and simple stuff. I dont 3d and I dont want to so I really am not going to get any better with it. As you can see I have a lot of new parts that I have not used and a lot of new parts on the heli. I have kept a lot of the old parts because they are not bad or damaged. If it had any sign of wear I just changed it. What can I say, I like to work on the heli more than I like flying it. What you see is what you get. Everything in the pictures is included. All of the new items I have are still in the plastic bags. All of the used stuff or things that I have opened are out of the plastic bags.
    THIS IS A COMPLETE READY TO FLY SETUP. THIS IS EVERYTHING YOU NEED TO GET FLYING AND STAY FLYING. DON'T BE FOOLED BY OTHER PEOPLE SELLING READY TO FLY SETUPS THAT DONT HAVE A BATTERY
    CHARGER, BATTERIES, ETC, ETC, ETC.
    Parts
    The following items are installed on the helicopter:
    Futaba T7CAP transmitter programmed in and ready to go, all trims are set!
    Futaba T7CAP charger and battery installed in the transmitter
    Futaba fp-r148dp 8 channel receiver
    upgraded receiver antanae
    otter ESC electronic speed controller with male deans connector
    hitec hs-65hb servos for the head assembly (best for the head assembly)
    airtronics 94761 digital servo for the tail rotor (best for the tail rotor)
    44 is the number on the crystal in the transmitter and the receiver
    hdx superframe with true 120 degree servo layout (better than the trex 450 se v2 frame)
    hdx main rotating assembly (I am including a brand new trex 450 se v2 main rotating assembly as well)
    hdx 3550 Kv upgraded high power motor
    hdx flybar paddles and flybar weights
    align trex 450 se v2 tail rotor assembly with new bearings
    align trex 450 se v2 tail rotor belt
    align trex 450 se v2 flybar
    align trex 450se v2 tail rotor belt gear and bearings
    align trex 450se v2 main shaft
    align trex 450se v2 large gears and auto rotating assembly
    align 325 wood main rotors
    align aluminum tail boom
    align trex 450 se v2 carbon tail boom fin and rear fin
    align fiberglass canopy painted yellow
    These are items that are not installed on the heli that are used or that have been taken out of the package (everything that is out of the plastic bags is used but still usable):
    Wing tote helicopter carrying case with enough storage for everything.
    Triton computerized charger discharger and cycler with the proper batter connectors installed on it.
    Power inverter for the charger so you can use it on 110 volts. Thats the plug in your house.
    4 (yes, 4 of them) megapower 11.1 Volt 2100 mAh 3S Li-Polymer 20C Batteries (This will keep you flying for a long time and prevent you from waiting for batteries to charge)
    Here are all of the voltages of the batteries that I measured last time I used them. They are all balanced and are always stored at around 11.3 volts. The batteries are all in great condition and work great. As you can see from the chart below they were all balanced within .03 volts the last time I used them. I balanced them out perfectly after I took this data.
    pack 1
    3.9
    7.81 3.91
    11.73 3.92
    -11.73
    pack2
    3.99
    8 4.01
    12.01 4.01
    -12.01
    pack3
    3.77
    7.57 3.8
    11.39 3.82
    -11.39
    pack4
    3.81
    7.63 3.82
    11.45 3.82
    -11.45
    One blue canopy that needs a small repair. I don't care to spend the time to fix it since I had another one.
    eflite rotor pitch gauge so you can set up the rotor pitch yourself
    another otter ESC electronic speed control (This one was acting up so I got another one. I think I just was not programming it correctly)
    extra carbon tail rotors (they have a small chip in them so I swapped them out) and an extra set of plastic tail rotors
    gears for the hitec servos (you will strip one eventually)
    2 mainshafts
    1 align rear servo control rod (connects the servo to the tail rotor assembly)
    1 large white main gear
    1 tail rotor belt gear assembly that goes by the gyro
    miscelanous nuts and bolts and small bearings
    servo horns
    blade stickers
    3 mainshaft sleeves
    Here are all the items that are brand new in bags:
    2 align mainshafts
    3 aligh mainshaft sleeves
    1 large align mainshaft sleeve
    1 complete linkage rod set with ends
    3 extra linkage rod ends
    1 align main shaft assembly
    1 align carbon fiber tail shaft boom
    1 align aluminum tail shaft boom
    2 align servo mounts for the tail shaft boom
    3 align 325 wood rotors
    4 align flybars
    1 align seesaw flybar joining piece (I am not sure what its called)
    2 align silver balls for use with the linkage rod set
    1 align tail rotor belt
    2 align carbon tail rotors
    4 black plastic align tail rotors
    6 align tail rotor shafts
    1 align tail rotor shaft gear
    another linkage bar set
    align main gear (blue)
    Payment and Shipping
    Shipping to Lower 48 United States only
    Local pick up also possible.
    I will ship within 3 business days of approved payment.
    I accept PayPal from verified Paypal members or Cash if you want to meet in person.
    I will only ship to confirmed Paypal addresses.
    I am not responsible for lost or damaged packages in the mail, but insurance is required. Signature is also required.
    Due to the mature nature of this hobby all of this is sold as is.
    I will only ship with tracking numbers, fully insured and signature required on delivery.
    Thank you for looking and buy it before someone else gets it.
    This is a killer deal and it includes everything you will need to fly and everything you need to keep flying. PLEASE DONT LOWBALL ME.
    PICTURES:
    Val for president!
    Facebook.com/TracyATL
    long dong silver hondaman050's Avatar
    dallas
    very very nice write up....
    Thanks. It took forever.
    Val for president!
    These helicopters are very easy to fly and stable. They fly nothing like the cheaper smaller ones.
    white power!!!!!! .....1
    Dacula GA
    so why then did rob and big break like 20 in 10 min?...lol
    j/k great setup
    wish I had some spare cash to snag this
