Results 1 to 10 of 10
Thread: smoking
    athens
    Default smoking
    My civic is smoking pretty bad when i stand on the gas. Any ideas? do i need a rebuild or swap?
    SwiperNoSwiping!!
    Its either the valve stem seals, or the valve guides, or the piston rings/oil ring.
    Then again, im also assuming you are talking about the kind of smoke that comes out when oil is being burned... I'm also assuming you're not confusing that same smoke with what happens when vtec engages as well.
    u remind me of a wigger !
    Jan 2003
    Ummm, then don't "stand on the gas"......
    SwiperNoSwiping!!
    Quote Originally Posted by Jaimecbr900
    lol +whatever amount i can give
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    lulz. i'm happy to see that being put to good use. like i said in the thread, if you don't take a few minutes to follow the guideline im not helping anymore. if someone uses a little common sense, i'll go out of my way to help out.
    Who knows?
    Norcross
    next time ur car starts to smoke pour water in the intake. then killyoself
    JDM TYTE AnthonyF's Avatar
    FUCK...my locked function doesn't work anymore. LOL
    This thread blows though. If your car is smoking, why would you continue to MAKE it smoke? Doesn't seem intelligent.
    -Ant.
    The Carbon Fibered R6
    Columbus
    don't stand on the gas...it will alst longer. and its prob piston rings. if it bothers that much, either:
    a- do a swap
    b- drop the block and get a shop to replace the rings
    c- keep standing on the gas and asking why it smokes
    ballin on a budget hondalover00's Avatar
    ga
    Quote Originally Posted by 99jdmLs
    a- do a swap
