Thread: im having a little trouble...
    Certified Gearhead Drake's Avatar
    Fayette-nam.
    Default im having a little trouble...
    getting the starter off of my S13.
    suggestions?
    and how would i go about swapping one 5spd transmission to another 5 spd transmission?
    if you can help i'd mucho appreciate it.
    1990 cb7: grocery rocket
    first tip is to get u a manual.
    * Remove clutch operating cylinder from transmission.
    * Disconnect speed sensor, O.D. position switch, top (4th) position switch, reverse lamp switch and neutral position switch harness connectors.
    * Remove starter motor from transmission.
    * Remove propeller shaft. - Refer to section.
    * Insert plug into rear oil seal after removing propeller shaft.
    * Be careful not to damage spline, sleeve yoke and rear oil seal when removing propeller shaft.
    * Remove exhaust tube mounting bracket from transmission.
    * Support manual transmission with a jack.
    * Remove rear mounting bracket.
    * Lower manual transmission as much as possible.
    * Remove shift lever with control housing from transmission.
    I Am, A Stunt Man
    yes, let hanes, or chilton be your best friend, and where are you located? buy my friend and i some food and drank, and we will help, if you are close around
    Photography & Design
    2nd tip is to buy a 240z
    NIKON Squad | D90
    Fayette-nam.
    thx kev. now how about that starter? haha
    Quote Originally Posted by Drake
    There are 2 bolts that hold the starter on. they run from the back of the car to the front through the bellhousing into the starter. Then disconnect the wiring from the starter and it will just fall out.
    Fayette-nam.
    thanks yall. reps to all!! now if i can just get that dern tranny out..
    LOL, it cant be hanging in there by much.
    Fayette-nam.
    lack of time and manpower. delivering pizza for a hole in the wall place in a f150 is killer, i miss the 2-4.
