Results 1 to 11 of 11
Thread: I want a stock turboo
    Norcross
    Default I want a stock turboo
    Ok, well i have a civic with a b-series and i want to use a turbo from a stock boosted car, such as a talon/sr20/srt4. Im really looking for something internally wastegated. My question is: which should i get? and am i going to have to get some kind of specially fabricated manifold?
    Stang Mod slostang's Avatar
    Southside
    big 16G
    Gwinnett-Grayson
    i have heard you can use the older eclipse turbo's on dc's/civics
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    530TQ + FWD = FAIL!! Kason23's Avatar
    Rockmart
    You cannot use a Srt turbo... its built so that it can only be used on the stock manifold. But I have also heard of the old dsm turbo being used on civics
    Neon PoWa
    Now Delta 46 equipped
    432whp/425wtq on lower boost
    Quote Originally Posted by j0nbunklah0m
    It all depends on what your power goal is. Decide on that and go from there.
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Quote Originally Posted by slovic
    big 16G
    x2. A stock Talon or Eclipse 14b or 2nd Gen T25 is a very small turbo that you will be very limited with. I've heard of a lor of Civics using the T25 but I would not. Maybe a bigT28 though. So I would use either a 16g, big 16g, or even better a EVOIII big 16, and yes there is a difference and they are relatively cheap. A EVOIII < 600 bucks or an equivalent Big T28 for about 900 bucks. EvoIII is the way to go IMO
    southside ATL
    Norcross
    thanks all, and reps. if i were to go with a 16g, would i need some kind of special manifold? im not looking to make too much power, however i want a turbo that spools quick
    southside ATL
    damn not that much input. no one comes into forced induction section.
    The Big 16G has a standard T25 exhaust inlet flange, the same general flange that most Honda turbo manifolds use. You would need to fab up your own downpipe of course, but it should not be too difficult to make. The Big 16G turbo has put down over 400whp on several cars with the correct mods, and it will spool very nicely on a Honda engine.
    IA MEMBER Killswitch Performance's Avatar
    Couple things..
    1. SR20 is not a car.
    2. You need to get whatever manifold you want to have the same exhaust flange as the turbo. So.. You want a T25/T28 from a SR20, you'll need a T2 flange.
    Also note that the T25 from DSM's are not even close to the same as the T25's from an SR. So you'll need to make sure which flange you need, and pickup a turbo that will bolt on. Mitsu and Nissan flanges are different.
    3. Pick a turbo based on your power goal. Pick a power goal, pick a turbo. Read up and see what people have made with that turbo, and go from there. Don't expect someone to pick your turbo for you. Its your car, not theirs.
    Tyler @ KSP
