Results 1 to 11 of 11
Thread: Smoke and boost
    Stay Humble
    WV
    Default Smoke and boost
    OK! ive heard mixed rumors as far as having a tiny bit of smoke and boost. the worst is your engine will blow etc. is this true? and what are my chances of this actually happening with all stock internals
    Nearly every boosted honda ive ever seen even with fresh engines smoke. Its normal with a safe AFR in boost to get a little fuel smoke (black). Its very common for turbo engines to use a little oil as well since blowby is increased greatly. The only way you will blow your engine is to run it low on oil, have a bad tune, or try to make to much power for your internals. Smoking doesn't actually hurt in small amounts.
    Stay Humble
    WV
    ok man. that makes me feel hella better. all it is is a little oil slippin past pistons? correct?
    Past the rings, yes.
    Stay Humble
    WV
    thanks man
    tUrbo D ... 00CiViC00's Avatar
    yeah mine smokes ,a lil right before i shift at WOT
    my momma's house
    Like my coke dealer used to say, "too much of anything is bad for you, so EVERYTHING in moderation."
    I don't know if that will help you or not, but it looks like some awesome advice.
    Trend settin'
    Stay Humble
    WV
    Quote Originally Posted by TheChosenOne
    hjahahah thats baller. thanks man
    as long as you dont get too boost happy and crank it up you will be fine. its just compressed air.
    I CAN HAZ 8 CYLINDERS?
    Cameron Flaisch Photography
    Canon Shooter
    the county
    with any honda motor on stock internals, you should be able to run safely around 8psi and be fine, just get a good tune and don't go boost happy like Cam said.
    Stay Humble
    WV
    ok. thanks guys =]
