Results 1 to 26 of 26
Thread: Testing waters
    Default Testing waters
    if i start parting, i would like to sell as the following parts
    Transmission 2200 obo
    engine 3500 obo
    turbo kit 2800 obo includes 3 inch exhaust with muffler
    ecu/ with hondata 450 (has been unlocked for all turbo and datalogging)
    wheels with trade of 15inch steelies 800 obo
    shell 2300 with wheels
    1500 with out
    May trade for LS1 or LS6 parts...
    Have an integra im trying to get rid of soon... just bought a CTS V and wanna do some work to it rather than stay in the import scene.
    I have a GSR that needs paint a tune and a new fuel pump relay. i dont have the money to really finish this project and would rather make some one happy.
    i will sell the car out right asking 8500... as it sits.
    the motor
    B18C1
    Bottom End
    9.0:1 CP pistons
    Eagle H rods
    Eagle block guard
    Blanced gsr crank
    Blueprinted block
    Head... just installed new Skunk 2 turbo stage 1 Cams
    head was ported
    BBK SSI intake manifold
    Power 70MM TB
    Hondata Intake gasket (newly installed)
    Ignition
    MSD External coil
    MSD spark plug wires
    Moroso Ignition box
    NGK 3330 Spark plugs
    AEM Adj cam gears
    Fuel
    Warbolo 255 fuel pump
    RC 750 CC injectors
    AEM fuel rail
    Areomotive FPR
    has a new fuel filter
    Suspension/ brakes/wheels/ tires
    Eibach Drag springs... lowers 1.5 front and 1 in the rear
    Energy supsension throught the whole car... it was the Hyperflex kit and i also installed rear trailer arm bushings...
    KYB Shocks
    Stock GSR upper antisway bar
    Megan Racing H Brace
    Upper and lower anti sway bars in the rear
    Racing Traction bar
    Brakes are Duralast Gold rotors and pads... new maybe 200 miles
    Wheels FNR01-5 wrapped in new BFGoodrich 215/45/17s g force tires
    Transmission GSR Rebuilt by Peter @ balanced performace
    Has ITR LSD
    Fidinza 7 # racing flywheel
    ACT stage 4 clutch
    Gear Speed Carbon coated syncros
    LS 5th gear... properly installed
    Turbo
    garrett T3/T4 68mm turbocharger
    godspeed intercooler and piping
    Tial 38mm wastegate
    Custom ac compatible log style manifold
    3 inch turbo back exhaust, straight pipe magnaflow muffler
    Greddy Profec B electronic boost controller
    Greddy RS BOV
    AEM 3 bar map sensor
    Hondata S200 with P72 ecu
    Cooling
    New water pump (new timing belt)
    aluminium half sized thick with extra quart capicity leg
    new hoses
    Turbo as a turbo blanket for reduced engine temps
    heat wrapped exhaust
    other things...
    alpine radio
    has a new oem from acura 98 front bumper
    has the turn ambers
    black housing head lights with 10k HIDs
    ITR front lip
    98 rear bumper (new)
    JDM air bag block off
    JDM clock Block off
    ITR shift boot
    Has GSR shift knob and Skunk 2 one as well
    Boost/AFR/Oil pressure/volt/water temp guages
    underdrive pully
    There is probably alot of things i left out, but everything in this car is new... its been a two year project. I was in school full time and worked full time and paid for my F250... didnt have too much extra cash to toss at a project car.
    with out the Hondata intake gasket and heat wrapping and ac removed and with stock gsr cams and 3 inch intercooler and piping (oversized at the time) it made 427 WHP on 18 psi... new tune with said mods should do approximately 500- 525whp on 20 psi. this is on pump gas. c16 maybe 550-600 at 23-25 psi.
    This car was owned by me for two years and may have been driven 1000 miles... i spent TONS of money in this and now Owning the V i wanna build me a bad V8. I have tons of reciepts from balanced and parts purchased. this car just...
    Hoping someone wants to pick up my loss at a fair price. i really dont wanna part it out unless offers are made on categories... this amount of power should do high 10 with a good driver and a little traction... We g teched it on the street at 13.9 with passenger spinning through 3rd at 427 whp @ 121 MPH... with the cams 2 more psi and lower intake temps... should get 80-100 hp... no telling what it can run. This was in a full weight 4dr gsr.
    [IMG]http://i45.photobucket.com/albums/f82/spencer1715/integra005.jpg
    [/IMG]
    PM if interest for more info or pictures
    other things i forgot... i have another hood to go with it... have ac to reinstall if you want it, ITR spoiler and few others...
    Also the battery, starter, shocks, brakes, energy suspension, cams,intake gaskets, fuluids tstat oil lines for the turbo... nothing on this car has over 100 miles except the motor... motor has about 10k on the build... transmission may have 50 miles on it... at best... everything is NEW
    text 678 522 0218
    your moms house
    wrong section dude but nice swapp
    (((((No more 4 door))))))
    I guess it is... but I might be willing to part in sections
    turbo
    engine
    tranny
    shell
    like I said seein if people are looking for things
    Im leaking VTAKK!! Burnz1one's Avatar
    Pauldin County
    so you wont part any body parts first? Or are you just selling the car as a whole?
    ya cause I need the bumper, hood and headlights.
    your moms house
    how much for the turbo kit
    How much for the skunk2 shift knob?? LMK asap. Txt me at 7708963263
    damn, i want that penis
    i texted you about the shocks, hit me up
    Pauldin County
    no no bumper is mine!!
    ekksun miguelvqz's Avatar
    how much for the tranny pm me
    i am going to leave this up a bit to see what everyone is looking for... id rather a lump some of cash ...
    i honestly have too much in the transmission to sell it by itself... i had to buy 2 syncro kits so i could get the ls 5 gear
    600 in sycros
    350 for the clutch
    150 flywheel
    intermediate and main shaft for 5 cost me 300 for both
    ITR LSD 450
    rebuilding id have to check i have nearly 2k in the parts alone, and then the rebuild...
    its too hard to put a price on it... i drove it 20 miles from balanced performace from my house...
    thats why id rather sell it as a whole... i just dont wanna get nickel and dimes for all this crap... and then spend money out on bs things for my car...
    If some one were to buy the turbo kit, motor, trans, ecu, and all the electronic goodies id let them go for about 7000... this car has easily easily 12000 under the hood alone...
    Yum-Yum Racing
    how mu ch for front bumper
    ttt
    engine 3500 obo
    1500 with out
    Whats next? lcortes32's Avatar
    Dec 2008
    Atlanta/SO*CAL/Nashville
    Gl dude
    93 Civic EX - Current
    95 Acura Integra GSR-Traded
    99 civic ex-Traded
    95 Civic EG DX Hatch -Traded
    96 Civic DX Coupe -Tradded
    98 Civic EX Fo' Do' -R.I.P
    93 Civic Si Hatchback (Miss you so much Buddy)
    93 Acura DA9 (R.I.P)
    97 Civic EK Coupe(tradded)
    97 Accord SE (traded)
    will need it on here... so many low lowballers
    tx3
    May consider a straight up trade for a small truck in good condition... lmk what you got!
    140 on one wheel
    columbus, ga
    part the whole intake manifold setup? lmk
    will keep in touch on the manifold
    OBO
    still up for sale
    any one?
    anyone
