Results 1 to 40 of 48
Thread: to much poke?
    Gainesville
    Default to much poke?
    took my wheel apart today to change the ET is it doable with a smaller tire?
    or the way i had it
    JDMSK8R JEY$JDM's Avatar
    NY 2 GA
    sick
    PURP-a-trader PURP's Avatar
    leave it man. looks good
    stockbridge
    i dunno what ur talkin about but im diggin it.
    Sleeper Wagon
    Canton
    looks sexy...just give it some camber!
    I concur. If you're referring to lowering it more, don't. Looks great how it sits. Later, QD.
    Fake Suburban Environment
    What kind of suspension and spring rates? True coilovers front and rear?
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    Gainesville
    Quote Originally Posted by DinanM3atl
    H&R coilovers dont know spring rates
    Gainesville
    everyone side they like it but with do u like the new look or the last pix (the old way i had it)?
    Quote Originally Posted by Digipix
    I don't get it. Maybe if you had a pic at the same angle with before/after. And what did you do? Later, QD.
    Krispy Kreme
    looks nice if you can daily that on some bouncy roads!
    NIKOND80
    PG+K
    ccw replicas
    kennesaw
    i think it might just need a little bit of camber to make it fit into the wheel well, but still can be made to look better. id keep it that way and make them fit
    HF
    West Staines
    tis DEFINETELY do-able. if you wanna rock a smaller tire that'll be cool. but if you go a tad lower in the front you should be fine.
    NW Boonies
    Its pretty gangster id leave it! its what u think bro..
    ~DB4LYFE
    07 Honda GD3
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    very sick car
    Gainesville
    befor the center of the wheel was in front of the lip to make it fit but they tuck a lil under the fender as you can see here
    today i took the rim apart and put the center behind the lip makeing the lip (poke) is a lil out side of the fender as u can see here
    so what i am asking is do u like the tuck look or the poke look. get it?
    MOST HATED
    Upstate SC/ATL
    I love your car and your choice in wheels.
    Gotcha now, lolol. My bad. I like them both, myself. Are the back wheels also poked out? If so, ride on it and see how you like it and how it rides and how the tires might handle it. Later, QD.
    f.b.
    205 up front, spacers in the rear. call it a day.
    Gainesville
    yea the back it going to poke with camber i have to buy new tires but i need someone with a use 205/40/18 to test fit to even see if it will rub or not dont want to buy any thing tell i know it will work.
    if anyone know where a tire is i can test fit let me know 205/40/18
    IA Hater/Shit Talker
    Looking good, we need to do another mountain run!
    Some guy tandem's Avatar
    War-Town
    It looks great either way. But why not go lower.
    Gainesville
    Buy me some bags then
    $LEEK PreludeVTEC01's Avatar
    North Atlanta
    Looks damn good!!!
    My Flickr Page
    Car looks great in last pic.
    If it is H&R Coilover I would worry that spring rate is not high enough and you will hit fender. Will need more stretch for sure though.
    1997 M3/4/5
    2004 X4 4.4i
    Rallyist awestun's Avatar
    ⇦ Atlanta
    too much? no. Go lower.
    Quote Originally Posted by swollix
    Track event?
    1997 M3/4/5
    2004 X4 4.4i
    DRVEN ER OTHA DAY tubby's Avatar
    otp
    naw hard as fuck
    What The Hell
    Kennesaw/Acworth
    looks real good
    Pfft! ATLTSX's Avatar
    In a van down by the river
    Like the new look. Like everyone else said lower it with some negative camber with a little tuck.
    Mainstream Performance
    NYC/ATL
    Couple questions:
    - Wheels look like 18x8.5, correct?
    - Same size all around?
    - Same offset all around?
    Fronts look good with the new setup, plus gives you more exposed lip. However, IMO it needs 205s up front. To pull that stance of up front the rears need to have a little MORE poke than the front (again in my personal opinion) and given that the rear fenders are already more aggressive than the fronts, you need some spacers for the rears, or maybe hit up image for some larger lips, run 9s or maybe even 9.5s in the rear with the same offset, they will sit 6 and 12mm more aggressive respectively, which based on the pictures you car can easily handle.
    So, new look up front with some 205s, 1'' larger lips in the rear, keep the 215s on there. Stance achieved
    Gainesville
    The front is a 8.5 and rear is a 9.5 I have a 7mm spacer for the rear. I'm looking for a used 205/40 right now don't want to buy tires that don't fit
    vanilla sky.
    go negative about 2degreez/
    Track event?
    Nah I can't afford that. Unless you mean the straight track?
    Damn Torre, you need to quit lowering that offset before I come show you up in my next project Mustang.
    I haven't seen your car on 369 in a while. Are you doing well?
    Car Ram Rod. Dville nismo's Avatar
    douglasville ga
    Honestly man it looks good either way.
    Senior Member G.C's Avatar
    Forgot
    sexy car.
    :idb:
    I must say, I like it more the way it was. I like the tucked look.
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    nice! time to post my audi! =)
    Blistered Blazer
    Norfolk, VA
    LOVE IT
    NIKON
    Squad member | Nikon D70s
