Thread: keeps blowing fuses
    Default keeps blowing fuses
    my dashlights, tail lights, and parking lights wont work because i keep blowing fuses. ive pulled out all the bulbs and checked them and looked everywhere for a fucked wire. could a relay be the problem? if so which relay and where would it be located?
    this is the 3rd 1 in less than 12 hours. check your wiring for to the lights. there is something fucked up in there someplace.
    i have...im basically wanting to know which relay could be messed up and where it would be located.
    Columbus
    what work have you done recently on your car? headlights, tail lights, ect...did you put any hids or something?
    Quote Originally Posted by 99jdmLs
    hids have been on for 8 months with no problems. only things ive done recently are the universal o2 sensor, and the slim fan which i spliced with the original fan connector.
    ballin on a budget hondalover00's Avatar
    ga
    buddy of mine had same problem in a 94 eg and he had a harness plug under dash that was showing wires and he ended up with no tails. dash lights and dome light.....too forever to find...and a pain in the ass......good luck and check all plugs and connections
    Quote Originally Posted by hondalover00
    ill check that too...thanks.
    anyone else have any ideas?
    IA Member c-rex31804's Avatar
    Cataula
    i checked my bulbs and that wasnt it either apparently theres a bare wire somwhere under the dash or somethin
    Senior Member iam99x's Avatar
    Athens
    Make sure you're using the right fuses, and like others have said...look at every single wire. Ensure that all grounds are grounded. If you can, get some sort of continuity tester and see if you can locate any shorts. I don't really see the problem being a relay.
    I've always hated wiring problems, but I've dealt with quite a few.
    Good luck, bud.
