Thread: stupid question that i dont know
    the duckster
    Rome
    Default stupid question that i dont know
    my tire size is 195/50/15
    i know what the 15 is
    but what does the rest stand for?
    everyone gives me different answers
    Race Ready Developments Member #5
    Rome Crew
    Columbus
    Quote Originally Posted by ducky1177
    195 is the widest point of the tire's outer sidewall to the widest point of the inner sidewall
    50 is the tire's sidewall height from rim to tread.
    15 is as you know, size of the rim
    Quote Originally Posted by 99jdmLs
    Titties!!!
    depending on the rim you could use a 205/50/15, as that is what is on my si. it's a little wider and going from a 195 to a 205 i noticed a difference in corners, could also be that i went from an ok set of tires to some yokohama's.
    2wheels move ur soul
    Also, the "50" which refers to the sidewall height, is expressed as a percentage of the tire's width, NOT as an absolute measurement. The "195" however, is expressed in millimeters.
    Senior Member iam99x's Avatar
    Athens
    All of the responses given are correct, but the correct term for the "50," in your case, is called aspect ratio. This is a ratio of sidewall height to width.
    If you multiply the width by the aspect ratio, you get the sidewall height of your tire. This is a good equation to use when you're figuring some ball park ideas on tire fitment.
    Another thing, if you want to figure up the total outside diameter of a tire, you can take the sidewall height and multiply by 2. Then, add the diameter of your wheel. You probably won't ever need to do this, but at least you now know how.
