Results 1 to 15 of 15
Thread: Si tranny on a Z6????
    fuck it thug it JdM_EJ2's Avatar
    the streets where we burn sweets,Gwinnett county hoe
    Default Si tranny on a Z6????
    I'm dropin a boosted Z6 into a 4door EF and I wana use the Si tranny can I do that...if so what I need for it 4 example...clutch flywheel etc preciate it if you can help
    Quote Originally Posted by JdM_EJ2
    d series si right not a b16 got to get the clear.
    Southside Ridin HATCH
    If your talkin bout the D series one, then yes
    Yea its the d series cable Si tranny...cause rite now the Z6 is inmy coupe can I use that same clutch or I needs a different one?
    u should be good im not a expert at d series so id wait for a confirmation.
    your good man.. im 98% sure !!
    Jajaja what about the other 2% lol but alrite then preciate it
    lol.. i know the trans will bolt up fine..
    and as for the clutch and flywheel should be the same
    90-91 Si trans will use same clutch sohc from 90-2000. I used the stock z6 flywheel, EG clutch and 91 crx si trans with my old z6 swap.
    Preciate it a lot
    turbos
    it should work without issues
    TOO BIG
    Augusta Ga
    i know 300 % it will work ..
    93 sol Si
    95 sol S
    95 sol Si
    center field
    it will work got same set up
    ^^ take this guy's advice, he cant even spell henry co right lol.
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    reps
    2014 | Hyundai Veloster | Turbo R-Spec
