Results 1 to 26 of 26
Thread: how can i check my timing myself?
    Gwinnett-Grayson
    Default how can i check my timing myself?
    as the title says, how can i check my timing. i am starting to think after considering everything that it is my timing that is causing these idle problems. so how can i do it myself? can it be easliy adjusted myself?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Start the engine. Hold the engine at 3,000 rpm with no load (A/T in (N) or (P) position, M/T in neutral) until the radiator fan comes on, then let it idle.
    Pull out the service check connector located behind the right kick panel. Connect the service check connector with the special tool.
    3. Connect a timing light to the No.1 ignition wire, and point it toward the pointer on the timing belt cover.
    4. Adjust ignition timing, if necessary, to the following specifications:
    Ignition Timing:
    16°±2°BTDC (RED) at 750 ±50 rpm in neutral
    NOTE:
    * Shift lever must be in neutral.
    * All electrical systems should be turned OFF.
    5. To adjust ignition timing, loosen the distributor mounting bolts, and turn the distributor ignition (DI) housing counterclockwise to advance the timing or clockwise to retard the timing.
    6. Tighten the adjusting bolts and recheck the timing.
    7. Remove the special tool from the service check connector.
    Gwinnett-Grayson
    holy not english to me. lol. i would so rather have someone do it for me. or atleast watch me do it.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    its not all that hard takes like 5 minutes
    Gwinnett-Grayson
    so i have to unscrew the belt housing to show where the belts are?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    You don't need all that fancy equipment, just check your timing with a stopwatch or a watch with a second hand...
    lulz
    Quote Originally Posted by blacknightteg
    na the marks u need 1 is on the lower timing cover the others are on the crank pully.
    lulz
    L'ville
    lulz
    im going to see the tutorial on this one.... lol
    Gwinnett-Grayson
    wouldnt it effect the actual driving and not jus the driving if it was the timing though?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    f-ckouttahere. PRO®'s Avatar
    come again? lol
    Gwinnett-Grayson
    hahah wow. sorry, i wasnt paying attention. what i meant to say was : wouldnt it effect not only the idling but the driving as well if it was the timing.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    lol, yes it would. when my timing was off, my car would lag(in and out) when i stepped on the gas
    L'ville
    the idle might not suffer horribly if timing is off by a tooth or two, but your lower end will feel like crap
    Gwinnett-Grayson
    alright. cause my car drives fine, atleast i think so, i dont feel any lagging or anything. pulls fine.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    L'ville
    do you have a coolant bubble?
    speed is right, at 900rpm you should have a revolution of the crank every .06 seconds. i typically use a seiko stop watch.
    Exactly. It sounds to me that the spark plugs may not plugging properly. Either air is getting past the plug or the spark is not being suppressed. If the light of the spark is escaping at the plug then it can't be detected at the crank. I'd suggest removing the spark plugs and coating the threads with a thread locking compound to seal it so the light then can come out the crank and be properly timed. That's where a timing light comes in handy that the high end performance shops use.
    Gwinnett-Grayson
    if i did some type of thread locking material on the pugs. wouldnt that fuck up getting em out later?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    IA's Pedo-cord tdurr's Avatar
    Fayco
    i see wut u did there.
    btw to the op, dont do wut he said ^^
    Save ur engines!
    Red loctite not the blue or there could be future issues.
    Gwinnett-Grayson
    lol i figured you were talkin bs lol.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    lol he would be fucked.
    Would have to sell the car...or new engine lol!
