Thread: do h series a f series manafold interchange?
    LAWRENCEVILLE
    Default do h series a f series manafold interchange?
    I am droping in a f22b1 vtec motor in my 93 honda prelude that had a h23 in it. the fuel rail inlets are on the wrong side and the fuel rails do not look like the will interchange. do the intake manafolds interchange? meaning can i bolt the h23 intake manafold to the f22b1 engine?
    Hella stock member!
    No intake manifold will not interchange, however the rail should. I believe the h series inlet and outlet is on the driver side, and f series inlet on the pass side, outlet on driver...
    Correct
    LAWRENCEVILLE
    the rails do not look like they will interchange! pics comeing
    Hella stock member!
    LAWRENCEVILLE
    the f22 rail bolts to the manafold on the top of the rail!
    the h23 rail bolts to the manafold on the bottom of the rail
    Hella stock member!
    They will not interchange, I know first hand. You need f22a1 stuff and then it would bolt up. Not sure on the f22b1 head, but some of the f22a's I've seen have the IAB manifolds on them.
    IA.COM Junior Member 95LxCD5's Avatar
    Byron, GA
    your gonna swap ECUs right? if so can i have the h23 (P14) ECU for a low low price?
