Thread: Does anyone know how to wire up a relay for trunk pop?
    . eg mike's Avatar
    ga
    Default Does anyone know how to wire up a relay for trunk pop?
    Hey all....
    The Viper alarm manual says I can use my after market trunk popper but needs a relay... anyone have a guide as to what wire goes to what on the 4-wire relay?
    The output from the alarm is 200 mA (-)
    any help please
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Use the red/white wire should be the second channel on the viper and go to the relay, then out of the relay to the solenoid for the trunk release. That will send power to the solenoid when you hit the II button on the remote. The relay because of the negative that comes out of the alarm. Hope this helps it is really the only way I can explain it without having one right in front of me.
    Bender A. Rodriguez
    Macon
    google negative pulse relay wiring or something, should find some pictures of how to do it.
    Ryan Reynolds
    \m/>_<\m/ dorin48's Avatar
    Canton
    A 4 prong relay should have each pin marked if you look closely. The pins are 30 - power source, 85 - ground, 86 - acc. or switch, 87 power out. Wire it up accordingly. Hope that helps.
    Apr 2009
    Quote Originally Posted by Cool Cat Racing
    What he said. You have to go neg to pos through the relay. Been a long time since I have done it I dont remember the actual wiring of the relay. I went out to the shop to look for one and couldn't find one.
    . eg mike's Avatar
    ga
    So 86 is what I need to hook to the red/white on the viper alarm?
    Thanks for all the help!!!!
    also if you know more about the alarm stuff.... how do you program the remote for this accessory?
    . eg mike's Avatar
    ga
    Alright I got a problem!
    After all hooked up, I connect the battery in and the trunk pop stays active. I un-connect battery and it de-activates.
    Heres how I connected:
    30 - HOT 12v battery
    85 - Ground on body
    86 - Wire from alarm for acc
    87 -Wire to trunk pop
    What you guys think??
    Certified Gearhead redfire6i's Avatar
    southside
    This should be right assuming you installed a trunk release solenoid and it needs a positive trigger.
    . eg mike's Avatar
    ga
    Quote Originally Posted by redfire6i
    I wired it up like this said and still does the same thing. Once I hook battery back up the trunk pop engages non stop...
    Any ideas guys? Could my trunk pop be wired backwards? (-) (+)?
    . eg mike's Avatar
    ga
    Alright here is another diagram I found:
    Ok this looks like the on switch is switching on 12v supply... my alarm is providing a 200mA negative supply. Would I want to set it up like this?
    86 - 12 v
    87 - 12 v
    30 - trunk solenoid
    85 - (-) from alarm (acc)
    . eg mike's Avatar
    ga
    still didnt work hmmmmmmmmmmmmmmmmmmmmmmm
    one thing I noticed my relay has 87a not the '87'
    the remote is already preprogrammed, look in the manual for how to use it
