Hey all....
The Viper alarm manual says I can use my after market trunk popper but needs a relay... anyone have a guide as to what wire goes to what on the 4-wire relay?
The output from the alarm is 200 mA (-)
any help please
 Does anyone know how to wire up a relay for trunk pop?
				Hey all....
any help please
				Use the red/white wire should be the second channel on the viper and go to the relay, then out of the relay to the solenoid for the trunk release. That will send power to the solenoid when you hit the II button on the remote. The relay because of the negative that comes out of the alarm. Hope this helps it is really the only way I can explain it without having one right in front of me.
				google negative pulse relay wiring or something, should find some pictures of how to do it.
Ryan Reynolds
				What he said. You have to go neg to pos through the relay. Been a long time since I have done it I dont remember the actual wiring of the relay. I went out to the shop to look for one and couldn't find one.Originally Posted by Cool Cat Racing
				A 4 prong relay should have each pin marked if you look closely. The pins are 30 - power source, 85 - ground, 86 - acc. or switch, 87 power out. Wire it up accordingly. Hope that helps.
				So 86 is what I need to hook to the red/white on the viper alarm?
Thanks for all the help!!!!
also if you know more about the alarm stuff.... how do you program the remote for this accessory?
				Alright I got a problem!
After all hooked up, I connect the battery in and the trunk pop stays active. I un-connect battery and it de-activates.
Heres how I connected:
30 - HOT 12v battery
85 - Ground on body
86 - Wire from alarm for acc
87 -Wire to trunk pop
What you guys think??
This should be right assuming you installed a trunk release solenoid and it needs a positive trigger.
				Originally Posted by redfire6i
I wired it up like this said and still does the same thing. Once I hook battery back up the trunk pop engages non stop...
Any ideas guys? Could my trunk pop be wired backwards? (-) (+)?
				Alright here is another diagram I found:
Ok this looks like the on switch is switching on 12v supply... my alarm is providing a 200mA negative supply. Would I want to set it up like this?
86 - 12 v
87 - 12 v
30 - trunk solenoid
85 - (-) from alarm (acc)
				still didnt work hmmmmmmmmmmmmmmmmmmmmmmm
one thing I noticed my relay has 87a not the '87'
				the remote is already preprogrammed, look in the manual for how to use it
