Results 1 to 15 of 15
Thread: Emissons pasing concerning a swapped motor
    Gwinnett-Grayson
    Default Emissons pasing concerning a swapped motor
    alright so i have a swapped b20 now into my integra. can i still pass emissions. i know he swapped over th intake mani, distributor injectors and i am pretty sure the ls ecu, but will what do i have to worry about.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    TAT-GUY EL42's Avatar
    Notorious Tattoos
    do you still have catalyst converter? and does that engine have EGR?
    Where Am I
    u should be able to pass the LS and B20's just about the same, I've had B18C5 motors in integra's and they passed fine....
    Stang Mod slostang's Avatar
    Southside
    as long as there is no check engine light and a stock cat you should be fine.
    Indecisive SOB aguynamedpat's Avatar
    In your attic
    Quote Originally Posted by EL42
    Quote Originally Posted by Psycho View Post
    I don't know any dentists, but I got a dremel and a handful of oxycontin. If you got $50 we can make this work.
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    i see no problems it should pass and if they check the motor (i dont) i dont think they would know the difference and as long as you have a cat. which you probaly do you should be good
    Gwinnett-Grayson
    thanks yal. just wanting to make sure.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Gwinnett-Grayson
    I just had a thought, when they do emissions on cars, do they not scan the barcode on the block? Wouldn't they scan it if they do and it come up with info for a b20? I'm probably worrying too much, but being my first swap I feel I have too
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    :noitacoL
    Dude, you're gonna be fine, every car I've ever had tested was swapped. They're not checking if it is the right engine, engines get replaced all the time, they're just concerned if it passes the test.
    Quote Originally Posted by blacknightteg View Post
    u are over thinking this. go take your test pass and be done with it.
    Southside
    there are only two things an emissions tester cares about.
    one is saying "you passed, give me $25 and GTFO."
    the second is saying "you failed, give me $25 and GTFO."
    yea just go and get your emissions already lol
    Quote Originally Posted by slostang View Post
    lmao tru!!
    damn, i want that penis
    Gwinnett-Grayson
    yeah i will. i got a few things i want to tune up right quick before i do. but i will lol. sorry, im just making sure, its the type of person i am.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    JDM TYTE AnthonyF's Avatar
    If your CEL is NOT on and it's a 96+ newer vehicle and you are equipped with a cat YOU WILL PASS.
    -Ant.
    The Carbon Fibered R6
    :noitacoL
    DID YOU PASS?
    DID YOU PASS?
    DID YOU PASS?
    DID YOU PASS?
