Results 1 to 20 of 20
Thread: need new turbo,what size..
    Default need new turbo,what size..
    need to get rid of my laggy t3 Ebay turbo that hits full boost 1500k before my 6500 redline.
    Looking at Garrett turbos.
    My goals are 250+whp on stock block/internals *2.3L,Accord;F23
    Wanting quick spooling with better powerband.
    Looking at the T3: 57 trim or 60 trim.
    both have: flow: 53 lbs/min 678cfm . A/R HOUSING Available .48/.63 STAGE 3 WHEEL oil lubricated centersection. supportable of 475whp!
    what trim and what A/R housing should I go with?
    Thanks
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    What engine? I assume an Accord but Year and Engine would help. Other mods would also help like injector size, fuel pump, stock ecu, hondata, standalone? FMIC?
    Engine is listed; 2.3L 4cyl..5spd. 99' Accord
    but New build will include the new turbo,
    equal length log Manifold,
    3" DP with straight 3" to HKS hi-power muffler with dump tube routed to exhaust
    precision 440cc injectors
    AEM EMS
    walbro 255 fuel pump.
    using 2.5" treadstone intercooler piping
    with the Treadstone intercooler
    Apr 2009
    With only 440 injectors I would not go bigger than a T3/T4 Garrett with prob no more than 8 or so psi on the stock block. Also should get a better fuel pump. I'm not a Honda pro but I do know a little about Turbo cars in general. If I'm wrong someone jump in. I just know to run a T3 or a T3/T4 on my car I need at least 650cc injectors, but to get up to 15 or more psi I really would need 750's or possibly 850's That is on a DSM but cant imagine it would be that much different. T3/T4 50 trim is bad ass though.
    Apr 2009
    Sorry you did say walbro fuel pump. I didn't read right.
    530TQ + FWD = FAIL!! Kason23's Avatar
    Rockmart
    6500 redline? I say .57 trim in a .63 ar ... but if you wanted faster spooling and less topend do it in a .48
    Neon PoWa
    Now Delta 46 equipped
    432whp/425wtq on lower boost
    Certified Gearhead miro_gt's Avatar
    or you can go .48 and two 38mm waste gates (or one bigass one)
    Two wastegates is not at all necessary for what this guy is trying to do. One external 38mm wastegate would do just fine, or even an internally gated turbo would do fine. In his case, I would go with the .48 A/R for quicker spool.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    p.m. EmminoDaGreat. he has a bad accord thats boosted and works at mainstream.
    tUrbo D ... 00CiViC00's Avatar
    super 60 .... is what emmino had ,.... now he has a t3 hifi 60
    He told me the super 60 would be to small and would need 12psi to reach 250whp..
    I have a tial 38mm with 7.25spring
    get the hifi ., i think hes runnin 10 lbs
    known as Charles
    The turbo I am running is a T3 Hifi 60, ball bearing, with stg5 or 6 internals, it has a .48 exhaust housing (same as my old super 60) but a bigger compressor housing, and internals... It makes 260+ wheel at 9-10psi. and it spools faster than my old super 60, you can check out my graph in the mspi tuned section...
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    /\/\ that was me
    Here is the difference in the exhaust side T3 super 60 w/ stg 3 wheels, and the New T3 Hifi 60 w/ stg 5 wheels
    I can get the 57trim or 60trim in a stage3 wheel..so 57 trim with a .48a/r should be what I'm looking for? Or will the 48 just spin tires n crap
    the smaller the exhaust side, the faster the spool time, which is something you are looking for....also wheels affect that ...
    But will the smaller ar effect my power? Will it have power till I shift or fall on its face after 5k or so?
    Rockmart
    I would think a .48 would fall off somewhat compared to a .63. But the benifits of a faster spool is more then worth it
    Neon PoWa
    If you are worried about spool time, then get the .48 A/R. Since you are only running up to 10psi, do not worry about the .48 A/R dying off in the upper RPM range.
