Thread: Mazda RX3 wheels
    Default Mazda RX3 wheels
    Does anyone know the specs of a mazda rx3 wheels (mainly bolt patterns)?
    Certified Gearhead F8d2Blk's Avatar
    My guess would be the same as the datsuns? 4 x 114.3 but not 1000% sure.
    ^ thanks, that means I going to have two different type of wheels
    Stone Mountain
    Quote Originally Posted by F8d2Blk
    yea 1000% wrong
    R100, RX-2, RX-3, RX-4, older 929s, RWD 323s, RWD 626s and Series 1/2 RX-7 use a 4x110 bolt pattern. so pretty much you can use wheels from those cars unless you want to go aftermarket. the closest thing is ford's 4x108 bolt pattern, like on foxbody mustangs. but its not even close enough to make work.
    Quote Originally Posted by Major Motion
    yea 1000% wrong
    thanks, this helped alot!
    yea 1000% wrong
    I knew the 80's rx7's were 4 x 114 so I guess I figured those older ones were the same. Sorry for the bad info.
    IA Member RGRacing's Avatar
    yea 1000% wrong
    All the oldies, SA & FB use 4x110 - 1984 and 1985 RX7 GSL-SE is 4x114.3!
    Roland Greaux Racing
    RGR GARAGE -
    1979 SA LE, 1979 SA 60k
    1976 RX3, 1977 RX3SP
    1954 P/S BUG
    I have 3 4X110 wheels you could come get for like $20, but the 4th one is my spare.
    Stock FB wheels, 13 by 5
    MADE IN JAPAN nisman's Avatar
    sticks-winder area
    4x108 redrilled to 110 with shank style lug nuts (old cragers, etc. and toyota mag style lug nuts..) not saying its the safest route, but they have held up for me so far. only problem you will have is that the offset even on a foxbody is typically too positive for a mazda (atleast with mine, 15x7 35 offset, i still needed a small spacer up front.)
